just recently my car isnt starting without the need of a jumpstart. (r33gtst) i went to bob jane and checked it out. battery is perfect, alternator is perfect.
came up as an error though as power drain or something like that.
this has got me puzzled.
what could it be?
https://www.sau.com.au/forums/topic/223779-car-keeps-needing-jumpstart/
Have you checked the battery terminals?
Loose earth cable?
Happened to me couple of days ago, resulting in new terminals.
These two things that springs to mind with situation like this.
Hope it helps
Cheers
Grant
i had this problem in my old vk... (P.O.S. btw)
turned out it was dirty battery terminals... the battery was leeking some shit out (whitish in colour) that was coating them and preventing it connecting...
wash in hot water see if fixes :thumbsup:
also check all your belts for slipping
Yep, what you want to do is like GTR-ben said, grab a multi meter and use the amps setting and do some testing.
Another good place to test is your fuse box, when the car is off, pull a fuse on a circuit and use the multi meter probes to bridge the gap and if the car is off you should get next to nothing. (Make sure the probes are in the AMPS terminals of the meter, because they are usually different to the volts terminals)
Common things that do cause current draw when the car is off are internal lights, alarms and shorts to earth.
So that should at least allow you to find which circuit is draining ur battery overnight.
Hope that helps dude.
How old is the battery? Just because it checks out as ok doesn't mean it's accepting and holding charge. Check the battery voltage before you even crank the engine. Then check it while you crank the engine.
Is the alternator working properly, and the regulator. If the regulator (built into the alternator) is cactus, then it might be overcharging the battery. And batteries don't like being overcharged.
Hmmm, that is odd, batteries dont normaly last 12 yrs, i have an odyssey that is only a few yrs old and had to replace that on the weekend, you should here it spin up now with a 1000cca dry cell.
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
