just recently my car isnt starting without the need of a jumpstart. (r33gtst) i went to bob jane and checked it out. battery is perfect, alternator is perfect.
came up as an error though as power drain or something like that.
this has got me puzzled.
what could it be?
https://www.sau.com.au/forums/topic/223779-car-keeps-needing-jumpstart/
Have you checked the battery terminals?
Loose earth cable?
Happened to me couple of days ago, resulting in new terminals.
These two things that springs to mind with situation like this.
Hope it helps
Cheers
Grant
i had this problem in my old vk... (P.O.S. btw)
turned out it was dirty battery terminals... the battery was leeking some shit out (whitish in colour) that was coating them and preventing it connecting...
wash in hot water see if fixes :thumbsup:
also check all your belts for slipping
Yep, what you want to do is like GTR-ben said, grab a multi meter and use the amps setting and do some testing.
Another good place to test is your fuse box, when the car is off, pull a fuse on a circuit and use the multi meter probes to bridge the gap and if the car is off you should get next to nothing. (Make sure the probes are in the AMPS terminals of the meter, because they are usually different to the volts terminals)
Common things that do cause current draw when the car is off are internal lights, alarms and shorts to earth.
So that should at least allow you to find which circuit is draining ur battery overnight.
Hope that helps dude.
How old is the battery? Just because it checks out as ok doesn't mean it's accepting and holding charge. Check the battery voltage before you even crank the engine. Then check it while you crank the engine.
Is the alternator working properly, and the regulator. If the regulator (built into the alternator) is cactus, then it might be overcharging the battery. And batteries don't like being overcharged.
Hmmm, that is odd, batteries dont normaly last 12 yrs, i have an odyssey that is only a few yrs old and had to replace that on the weekend, you should here it spin up now with a 1000cca dry cell.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
