I've never had a problem with K&N filters, and they're a hell of a lot cheaper than the jap brands and come in a huge variety of shapes and sizes.
I've currently got an M's stamped k&n very large cone shaped pod on my 32. It's goodcos you can now get the cleaner and oil from pretty much any parts place.
Last I checked the smaller pods started at 140 or so and price increased with size.
Dont laugh but ive got a simota pod on atm, havent had any probs with it and have tried others on the dyno with no variation whatso ever. And the Simota one sounds good as well, can use the K&N cleaning kit to clean it
i got a k&n pod on mine and it sounds good. I got no air feed to it though so i guess it isnt really an advantage at the moment. But the pod is clogged with dirt n stuff, even after 5 mins of blowing it out with an air blower its still dirty as hell. oh well gives others a fairer race
Yo sweetr33.Man,never use compressed air on k&n filters or any other brand for that matter.You will damage the fine cotton gauze and be up for a new one.Much cheaper to use the cleaning kit in the end which costs around $30
I'm not a fan of oiled pods at all. Mainly, because I've heard they can foul the AFM. Also, from what I can gather, don't filter that much better than your standard dry mushroom pods.
I use a Trust Airinx and damn does it sound sweet :) I've got no idea on how well it filters, as I've now heard (after I bought it) that it is the best filter on the market, and also the worst filter on the market. I haven't had any major engine problems so I suppose you can assume it at least filters out the big stuff.
MIC33r, how much does the POD you have cost. The only query that i have is that i was goin to use the existing Blitz mounting bracket. The measurements now are 150mm flange size with an overall length of 150mm. It makes it difficult to buy a replacement pod.
Oh well gota keep searching
I bought it a while back from Takakaira, so I wouldn't know the current price. It was fairly cheap though and came with all the mounting stuff you needed.
They used it in the Evolution R 200SX. I found a copy of an article about it on the net, but it has disappeared. Here's a google cache of it though:
http://216.239.37.104/search?q=cache:nzLpZ...&hl=en&ie=UTF-8
I got a filter from this place in sydney for about $40, it is identical to my mates Trust AirInex II which cos a few hundred $$$
have yet to use it but its identical besides the trust sticker on the screw down part
do you know how good these filters sound? ppl ask my mate what bov he has, and its just a factory plumb back, but it must blow back through the filter cos it sounds damn awesome and the flow noise it makes must indicate that it isn't restricting it much
go the trust or the rip off one i got
www.flyn.com.au
Took my factory turbo off on the weekend, and for a turbo with 155,000 kms on it, its in great condition. Very little shaft play (whats considered normal???) but the leading edge of the compressor has slowly been eroded. Im guessing crappy filter to be the cause.
I have known for a long while my HKS filter doesnt really filter all that well, you can tell by all the particles that find a home inside the bellmouth. Anyway im trialling an Apexi filter until i can find time and money to go by the biggest K & N that will fit under the bonnet.... that is of course unless someone wants to swap me their Ms filter.
Originally posted by Sydneykid
Hi Guys, we use Pipercross filters exclusively in all our road and race cars, they are superb.
http://www.pipercross.com
As used in WRC, Supertouring, V8 Supercars, LeMans etc etc
Who sells them and how much are they for the 76mm neck version?
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
