Hear what you say re rears. They did say 'suck it and see' was a good option for the rears, but it's just one more thing to fiddle with later if it's not done now......Hotting cars up is one long fiddle and time consuming exercise. I know it's overkill but it's nice to know you've got a set up nailed, however much it might be overkill. A fool and his money eh.....Or is it a fool and his money and his GTR!
I'll drop you a PM re the other option. I'm 11th hour on ordering these, and pretty happy with my decision, but let me know what you've got in mind.
Oh yeah, had some camber and castor put on there, as well as front and rear HD sway bars and the turn in is now fantastic and understeer is drastically reduced, albeit I've not yet been back on the track yet. Wheel feels fantastic and funnily enough tramlining is much reduced too, which you might not expect. Got coilovers, but they are old and need replacing or reco'ing (more money). Rims are R34 GTR running RE55s. 245/40/18 I think they're SR2. Can't remember 100% without checking.
  • Replies 204
Posted Images
nice one. for poor people like my good self. ballpark me on the 355 6/ 343/4 option you went with? it seems to be the gun set-up. and i'm sure I'll need it when I get sick of the 34 brembos going on my old 32 now.
+1
I'm about to upgrade my 315mm 4pot APs to something this size. My existing APs were perfect for where my car was at (1:52 around the creek), but with more power and tuned suspension I'm looking for something 355mm up front.
My guess is it was between $6-7k for your setup Lotus.
+1
$6.8k.....Hurts just writing it down :thumbsup: . From my searches this is a good price too. There are many who will ask $5 to $5.5 for fronts only but to be fair the parts on offer do vary.
I doubt you're poor Mr BB.......
Thanks for that Nick. :) yeah $6.8 seems pretty good to me. if you're getting 4 X calipers, 4 X floating, slotted AP rotors, braided lines, good quality radial mount-lug mount adapters and a set of pads maybe even 2 bottles of fluid then it's a very competetive price.
a car with nice brakes is a joy to drive and gives you so much more confidence on track. but it's hard purchase to cough up for all at once.
Thanks for that Nick. :( yeah $6.8 seems pretty good to me. if you're getting 4 X calipers, 4 X floating, slotted AP rotors, braided lines, good quality radial mount-lug mount adapters and a set of pads maybe even 2 bottles of fluid then it's a very competetive price.
Yeah, I'll find out about the virues of great brakes soon enough. My pricing does not include AP rotors (they will add $), and I've heard many people advise against floating rotors be they bobbin types or strap drive. Bobbins are noisy and prone to wear and strap drive are apparently very fickle and easy to break can't be machined, don't like reverse braking etc etc. Mine are semi flaoting i.e. they have a tiny amount of lateral movement to allow for some thermal expansion, but that is all. The calipers have knock back springs so this goes someway to addressing knock off.
Warning - I might sound like I know what I'm talking about but really I'm regurgitating what others have told me. Remember, I've not even had the brake fitted yet. Three months ago I was writing to this forum for advice on how to make my standard set up work..........
What discs did you go for mate?
PWR. They are curved vane but other than that I know nothing of them. I ran it past 'Roy' and he had no experience of them other than to say they do some high end OEM stuff so couldn't be too bad. We'll see.
If anyone thinks they're no good, then keep it to yourself and let me find out for myself....! :(
This may amuse. It compares the pad from a Brembo F40 calliper to that from a Sumitomo calliper. Understand that the AP 6 pot calliper runs a pad that is another half inch longer (13mm for the metricated folk) & that it is about the same depth. Pad area looks to be 20% greater which will no doubt help temps. :cool:
Sorry for the blurriness. :D
Another random thought:
According to the fan affinity laws (look it up :devil: ) the relationship between an increase in rotor diameter and an increase in airflow through the rotor is cubic, ie double the rotor diameter = 8 times the airflow.
So a 296 to 324 upgrade will give approx 30% more airflow.
Just somethign to keep in mind when you start stressing about vanes....
http://www.skylinesaustralia.com/forums/Ge...Wh-t238964.html
Reckon these suckers will clear me new brakes laterally? New brakes = R34 Brembo = R32 GTR plus 15mm in terms of required lateral clearance. Long shot I know.
Reckon the'yre too similar for a second set anyhows?
Another off topic 'does my bum look big in this' question, thoughts on these re lateral clearance? I'm hating the red lip (but that can be sorted fairly easily) and I'm not sure about white (but that can be sorted too). They are light and Rays and forged and hopefully have good clearances and there are a couple of pairs floating around at a relatively good price.....
CE28's definately don't have as much clearance as TE37's. One of the guys on here, Aaron, had trouble fitting them over 381mm rotors from memory, and switched to TE's. For 356's they should be ok though.
After brakes come rims.......Ok, to open up the field with rim selection, who knows of any 17" rims that will clear my coming soon set up? Clearly both in diameter and laterally? Such a thing? 17" will give me cheaper tyres, the rims may be cheaper themselves and I've heard that 17 x 9.5 is the optimum handling size for an R32 GTR......
Thoughts? Suggestions?
Hey Nick,
Would you mind emailing/PM'ing me the exact parts list that you're getting for $6800? That sounds (I can't believe I'm about to say this)............ cheap for such a setup!
As we've talked about, I'm looking at the same (AP 6 pot front, AP 4 pot rear) for my car and I was budgeting a lot more than that to get it done!
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
