Item: Jetspeed front fenders
Age: not sure
Condition: good, need primer and paint
Price: 150 FIRM
To Fit: r32 gtst, or gtr
Contact: PM
Comments: Have never fitted to car, bought from forums about a month ago, but have decided to go with standard fenders, as they suit the kit i have a lot more. Will swap for gtst stock fenders, plus $50 cash.
Will get pics up early next week.
https://www.sau.com.au/forums/topic/223851-r32-wide-body-vented-fenders/
Mate am extremely keen...am in Brisbane and can pick up on the weekend - would you take $120?
pretty firm with price, and im going over seas on friday afternoon, so if your keen, it would have to be before then. i have a guy interested atm, so i'll get back to you asap
