Hi guys,
I get a loud crunch for about 1-2 sec everytime i start the engine and also loud tapping sound (sounds like pistons) when i first start my car in the cold morning. Now if i was to warm the car up, take it for a drive then turn the engine off to start it back up again to look for the sound, the sounds gone away due to it being warmed up. Hence, why is the reason i can't take it to any mechanic to show the issue. :domokun:
Ive only noticed this loud crunch for 1-2 on cold start after ive changed my oil to 'Elf Synthetic Oil 10W50'. This is pretty much all the relevant information i can provide from my knowledge, and also that the sound is coming from under the hood on the passengers side, kinda sounds like its coming from the head area on the passengers side where the turbo is and all.
Could it be that im using a real thick oil, hence is why its making weird noises on cold start till its warmed up?
Note: The crunch sound is only for about 1-2 sec on cold start and not constant whilst idling in cold or driving.
Much appreciated for any helpful response.
Edited by R33Turbo
https://www.sau.com.au/forums/topic/223890-loud-crunch-on-cold-start/
need a better decription of a "crunch" dude...
example
is it similar to some one standing on a aluminium coke can or like some one scrunching up a chippie packet,or someone crunching first gear??????? could be the starter motor drive not retracting quickly enough on start up cause the lithium grease on the shaft is cold and thick?? who knows.
Edited by nizmonut
actually it could more sound like short 'gear crunches' as well.
Basically, if the sound dies down after warm-up, it wouldn't be engine head related or anything severe right? So it wouldn't do any harm driving it around?
Edited by R33Turbo
i think you will find the rattle and the crunch will dissapear if you have rices for breakfast instead of cornflakes, a snap crackle n pop from the exhaust is usually a good sign of a nice flowing exhaust, however in this case drop the gluten from the crankcase and run some thinner oil as obviously what is in there isnt protecting the mechanically moving bits on startup.
yeah well im running 25w50 mobil 1 in my gtr and starts on the first cylinder to reach TDC, no knocks rattles, purrs beautifuly so yeah i guess so.
and dont be fooled by the advertising of "synthetic" a federal court ruling allowed the oil companys to label highly refined mineral oil as synthetic.... so you dont always get what you pay for. make sure its says 100% fully synthetic as apposed to
just synthetic
Edited by nizmonut
its not your starter motor sticking? is there actually a sound that continues on while the car is warming up?
Nope, as i mentioned above the the 'crunch' sound which sounds like 'gear crunch' is only to be heard for 1-2 sec after engine start then goes away. However, if i turn the engine back off and on to hear the sound again, it will still be there (when the car has not yet warmed up properly). If its been warmed up properly, you would not hear the sound regardless of how many times you turn the engine on and off repetitively, hence is why i cannot show the mechanic as i got to drive there with my car.
yeh id take a wild guess at starter motor also...
you could always leave the car with ur mechanic over night?? drop it off real late and get there early in the morn to watch them start it, so u know they aint taking it for a thrash...?
Leave the car overnight with the mechanic. That's the only way you will demo it to him.
nizmonut, you really using 25W50 oil? 25 is waaayyy too heavy, and 50 ain't much better.
PS - how about just having ONE thread on the problem.
Im planning on doing that if i have time for it, however can't do it at the moment. Does that mean 10W50 is real heavy compared to average oils as well?
what do you mean by turn my a/c off? like disconnect the whole thing? cuz my a/c will obviously be off when im starting the engine in the 'cold morning'.
If you had your A/C on when you last turned off the engine, it will still be on when you go to re-start. Make sure you turn it off before actually cranking the engine.
10 is a bit heavy for starting (which is the only time it's important), but not too bad. Nissan's spec is 7.5W30 - you'd probably be slightly better using a 5W40.
oh alright, thanks for ur help there blind_elk... so ppl are suggesting it could be the 'start motor' dying out, maybe it could be... then again it could be cuz my oil is to thick for the weather these days if thats wat ur saying blind_elk...
i think i'd try thinner oil to see if it goes away....
If it was the 'starter motor', where is it? how much to repair or replace?
Edited by R33Turbo
isnt nissans spec 7.5W40? maybe im wrong :)
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
