  • Replies 51
Got into it a bit more today, moving to Melbourne next Sunday so want to check out state of the pistons before I go away, that way I know how much I need to save up
Edited by Keeper
haha good to see your engine stand shows the good old rb26 droop too. they look terrible, ours drops about 15-20cm at the balancer as the weight goes onto it.
Also looks like you have sepearated the passenger side cv which is an utter pain in the arse. You need to pull the driveshaft right out and get a new boot on it
I got a bit of the ole RB26 droop on the engine stand too. I used another jack to support the front of the engine. Do you think its a bad idea to have all the weight on 4 bolts that hold it to the stand? With nicely sized bolts the droop is minimal but theres still a heap of weight in a fully assembled RB26. Was a bit worried about that with mine..
BTW: An easy way to remove the right hand cv shaft is to take the front diff inspection cover off and use a lever to push the shaft out from the diff center. Comes out easy like that.
Edited by Godzilla32
once the suspension was loose i just pulled on the caliper and it wouldnt come out as the boot held it on, once the boot was off it came off easy, did i do this wrong?
Head went to Gilberts Cylinder Head Service this afternoon to do porting, clearances, clean out and open up oil returns and general recondition...
Piston out time!!!
The bolt tray is filling up!!!
And there looks to be a little blow-by, I knew this prior to opening the prick up tho
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
