  Godzilla32 said:
Yeah i kinda know that feeling lol. Only have to read my signature :P
im almost finished the initial engine out guide
and i have!
just indexed, linked and bookmarked, and OCR'd the GTR service manual so you can click to links inside the book or even search for text, will figure how to share later on...
both in PDF
  • Replies 51
  Godzilla32 said:
There was already a book marked manual going around which i have a copy of. Still be keen to see your version of it. Where did u buy the manual from?
from some guy off ebay a while ago, i was hoping it would be better than most the online versions but it wasn't, still that same scanned pages from the nissan manual.
I made all the index's so you can click to follow to the page, mage all the page numbers line up so if you want to goto CH23 you simply type it in down the bottom in the page number selector, I added bookmarks for all primary sections and then split off into each sub section, then left the text recognition go for the night so if i want to search for something like engine removal and i am being lasy i can just search the text for it.
damn way too much time on my hands and not having my car around is getting painful!!!!!1111oneoneone
  • 1 month later...
  9krpm said:
Like your work keeper.
If you do ever produce a manual let me know. I wish I don't have to do what you are doing but if need be I would love to have some pointers like your manual and have a go at this myself :)
try this link and give me some feedback guys
http://www.scribd.com/doc/4964854/GTR-Engine-Removal
  Duncan said:
One suggestion about the guide, on p10 you talk about the drivers side driveshaft, it is a real bastard of course. but we have found that you only need to remove the sway bar link and the ball joint at the end of the control arm (at the 2 red nuts as you describe) once you've done that the hub can swing out freely enough for the driveshaft to come out. In fact 70% of the time you don't even need to undo the hub at all, just lever the driveshaft out of the diff using a pry bar between the head of the diff bolts and the lip on the driveshaft that nissan kindly provided for this purpose. Once the inner end of the driveshaft is about 50% out of the diff it will slip out freely as you raise the motor.
And same in reverse - if you remember halfway back in to line the driveshaft up into the diff, and lower the motor slowly and carefully it will just slip into place. or undo the sway bar and lower control arm to allow the hub to move out far enough.
I also think you didn't mention the negative battery to earth, it is easiest to remove at the engine mount and just leave it in the chasis. and the vacuum line to the map sensor on the firewall. but they are only little things.
need to do some adjustments after this weekend
  • 2 months later...
  • 5 months later...
  • 2 months later...
  • 1 month later...
    • Gotcha, I mean that is at least good to hear. Are there signs, or troubleshooting tips to make sure the transmission is operating properly?
    • Well thats probably not gonna happen right away. LOL
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
