Hello
I have a RB25 on my RB20 but I am saving for a stronger turbo that will allow me to boost more and get more hp. What turbo would be good to get for this? I dont have 2000 dollars to spend on a turbo. What can I get for 1000 dollars? My goal is 300-350 hp. I will do the fuel pump, injector and computer upgrade later
Help
Edited by 335
https://www.sau.com.au/forums/topic/223904-affordable-turbos-for-rb20/
Hello
Help
You are better off doing the ECU,full exhaust and fuel pump now before you go to a bigger turbo.
But if you want to be disappointed that your new bigger turbo is not making power because you are hitting R&R or running out of fuel then go right ahead.
+1
I have an RB25 with a high flow, at around 300hp i am maxing out the standard ecu, fuel pump and injectors, from what i know the RB20 injectors and fuel pump are smaller than the RB25 so i cant see you making 300 - 350 on your standard items.
There are 2 gaurentee's in modifying cars:
1) Power costs money.
2) You get what you pay for.
You have to spend the money and lay the ground work before you can step up, if you dont have an exhaust with full 3" turbo back including cat and dump pipe then that should be your first upgrade and will give you more power just there, pod/panel filter is also a must, then try upping the boost, after that ecu, injectors and fuel pump are next on your shopping list.
But if you insist on just going a bigger turbo then the easiest and probably best bang for buck would be an RB25 high flow.
Spend $200 and install nistune in your ecu.
Upgrade fuel pump, around $300
GTR Injectors $600
Find a second hand Turbo that will make the power u want
U could maybe do it all for 2K expecially if you find a bolt on turbo
GTR Injectors $600
Nistune/remap good option, nice flowing exhaust and FMIC.
Bosch 040/023 fuel pump for $180 delivered
You'd be mad to pay $600 for GTR injectors, you can get brand new (with warranty) 550's for that.
As mentioned many times: cheap, reliable, fast pick 2 of the three :P
Agree with all, except GTR injectors can be had for as low as $200(if your patient), but don't forget resistor pack ~$50 or make one for about $20.
You will have to budget for a tune, unless you confident in doing yourself.
While the RB25 turbo will run on the RB20 quite happily, it will have a lot more potential to be unlocked by a good tune
