  • 2 months later...
Intake temp sensor: 22630 - 95L00 ---- $160
Exhaust temp sensor: 22740 - AA300 --- $ 380
These were the prices that i paid.
:ninja:
And yes if you are doing a MFD in GTT etc as i did then you need to drill and mount the intake sensor in the intercooler and get
a female thread welded on your dump pipe for exhaust temp sensor.
Now do keep in mind that if you are doing this to a non Vspec GTR then it may be a better option to pay $ 600 more and get the Nismo
upgarde V2 for the MFD (PART: 2371B-RSR48) as it comes with the Exhaust sensor, You then get the bonus of higher boost (2 bar), oil pressure on MFD, G sensor, lap timer and data logger software.
Edited by 99 GTT
  • 10 months later...
Installed mine this week-- thanks very much for the above info everyone!!!
i mistakenly connected pin 46 instead of 45 to the AMB to show AMB intake instead of nothing and by using amb into 46 being exhaust temp it shows a reading of 500-610 range according to temp for exhasut temp. i then added pin 45 too and has a AMB temp for intake and also an exhasut temp reading-- now i know this isnt the real temp for either but it shows something rather than nothing. Also interseting to note the mfd must use te signal sent from the sensor and do something wht it to present its reading----for example i had the AMB reading 8 degrees through intake, and while wired to exhaust it read about 580 degrees... so the samesignal sent by the sensor is interpreted differently by the mfd. I know having these wired up isnt the correct plg so incorrect temp readign, but at least it isnt showing nothing anymore :)
  • 4 months later...
  • 5 months later...
  • 3 months later...
  • 1 year later...
I decided to keep my MFD after not receiving solid buyers.
custom panel to keep the buttons in-order.
I decided to remove the "MFD" characters because I'll purchase a FULL-RACE ETS PRO unit and use the space to place the switches and knob.
My only beef is that I don't have oil pressure per not having the MFD2 update by NISMO. I haven't decided if I want to upgrade to the NISMO version or if I just want to purchase a dedicated oil pressure gauge. I'm not a fan of gauges but I do have an AEM AFR gauge...
Anyway, does anyone know how the MFD 2 reads oil pressure? Does the system come with an additional oil pressure sensor?
http://www.nismo.co.jp/en/products/competition/ie/pdf/ie01.pdf
i didn't find anything on NISMO's site.
  • 2 years later...
This is an amazing thread, much appreciated! I am currently collecting the last few parts for the MFD in a 4 door w/ R33 RB26. The only problem I am having so far is when I cut into my dash [i dont have the gauges] I am not sure if the 2 metal brackets will be there or not. Can anyone shine a light on these things?
Ive found some pictures that show that the brackets are not part of the metal bar below the dash, and when the dash is pulled out these brackets come with it. I am assuming the triple gauge brackets and MFD brackets are the same, but Im honestly not sure.
Again any info would be greatly appreciated!
Pic of brackets in removed dash:
Edited by tommytomatoes
  • 1 year later...
Would like to add a few thing to this thread after my install a while back and learning a few things online.
Standard R34 GT-R only displays 5 rows of data on mfd, V-spec I/II/M/Nur/N1 comes with 7 rows of data, normal GT-R does not display intake and exhaust temp data. Most people already know that getting the Nismo v2 mfd upgrade will get intake and exhaust data (comes with exhaust sensor) as is what I have.
There are ways to display 7 rows of data on standard GT-R without buying the exhaust sensor or the Nismo upgrade. As all R34 GT-R comes with intake temp sensor, you will see it on your intercooler driver side. The exhaust temp sensor connector is on the passenger side next to turbo outlet, you will see a female connector with 2 holes in it. This is where the exhaust sensor hooks up, however if you don't have the exhaust sensor and still want to display 7 rows all you have to do is get a wire and plug it into the connector by shorting it and then running the self diagnosis. You should now see intake temp values and --- for exhaust temp if you don't have exhaust sensor.
This is probably the best and easiest way as you don't have to take out your mfd and jump wiring the back. I have not tried this personally but this youtuber has got it working.
Credit goes to this youtube video:
  • Like 1
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
