Hi, Guys
I m just a newbie to own a factory BCNR33, and would like to do some upgrades
Lots ppl said the factory turbo can not go higher than 14psi (16psi is dangerous) or the turbos will be blown
If I modify the turbos to steel wheel one (HKS GT-SS,Greddy T517, R34 N1 etc)
is the factory engine bottom possible to be endured at a boost about 17-19psi to have 300kw atw?
we just ignore fuel system upgrades (injector or fuel pump), focus to factory engine tolerance to discuss
coz I m quite curious to know is factory RB26 really possible to have 500-600hp (at flywheel)?
or it still need to make bottom forges to have 300kw atw (about 360kw/480hp at flywheel)
hope guys to give me some suggestion :)
https://www.sau.com.au/forums/topic/223933-original-rb26-tolerance/
IF.....and I stress IF the bottom end is fresh and without damage, then yes...it will easily handle your required 300rwkw. In fact, 400rwkw is fairly obtainable if you have the correct supporting systems.
If you have no idea on the condition of the engine, then it is really a question of how long until it breaks. You never really know.
some things you can do to determine it's condition are:
Oil pressure test hot
Oil pressure test cold
Compression check hot and cold
check condition of oil and even have it tested by a third party if you wish
And then even if all these items are perfect....a shit tune will destroy it in no time.
You need to make sure your fuel system is up to speed and your tune is perfect.
i dont no wat ur talkin about about those factory turbos not goin ova 14psi lol my mate ran 22psi for 18months finally it blew lol.
you can do article search and ready them, lots ppl suggest do not over 14.7psi (1kg/1bar)
coz BNR32 BCNR33 GTR standard turbo wheel are ceramic made not steel one
i had blown ECR33 GTS25-t's turbo before, the turbo ran over boost at 18-19psi then blown immediately(wheels only) :D
so I m quite careful to face the boost setting evenif the turbos of "GTR" :P
but I still would like to hear more sounds to discuss and learn the boost up setting of GTR :)
No idea what your on about more to the point.
Its been proven time and time again, GTR turbos fail above 14psi
When the turbos fail they can also take ceramic dust into the motor, destroying pistons and the like.
Frankly, your mate was stupid.
Hi, mate
so is health factory RB26 engine possible to endure 18-19psi boost if turbos are changed to a/m steel one?
does the factory fuel pump (190L/H) or factory injector(440cc) must upgrade to suit 360kw at flywheel/motor ?
hope you may give me a little suggestion :P thanks
300rwkw = no problem for a street driven good condition RB26
without upgrading fuel pump and injector can do 300rwkw?
RB26 is a amazing engine :)
coz I just tranfer my ride from SUBARU EJ20
so I had quite lots question about RB26 .... shamed :P
however thanks for your answer :D
RB26 is a amazing engine :D
so I had quite lots question about RB26 .... shamed :D
however thanks for your answer :)
Like to say smart tranfer and welcome to the rb26 world. :P .
No looking back now.
Edited by Rav
coz I found too hard to have 300kw with EJ20 (exhaust too long and lagging to push large turbo)
evenif its big enemy 4G63 is quite easy to have 300kw without lagging (inline engine's advantage so as RB series)
but EJ20 ... sad, you need to pay huge price to have 300kw maybe doulbe/triple up :D
i still love subaru, if i had budget, i will buy one without powering modify(just do handling modifications) to enjoy driving it :D
at this moment I just want to large output monster, i choose GTR to be my partner :)
Edited by shawn.szutu
no you won't get to 300 awkw with standard injectors, fuel pump and air flow meters. But they are pretty cheap to upgrade.
with those, boost controller and steel turbos 300+ is easy with a healthy engine
You can actually make 300awkw on standard afm, injectors and f/pump. Just.
Even tired GTR fuel pumps are capable of supplying fuel for 300. The AFM's are right near max but if you keep the inlet temps down you will make the figures. Also injectors run at approx 85% if tuned correctly and assuming the pump is good.
You would be stupid to leave these things unattended anyway but it's till possible if you want to squeeze it out.
85%? My r32 gtr was at 98% at 290 rwkw!
You can actually make 300awkw on standard afm..
True.. My mech has shown me dyno slips of 350kw with standard afm's. He also says, he finds them better and easier to tune for 300kw applications.
cheers Tomek
    • Hi everyone, just looking to see what's available in the GTR seat options, testing the waters on what's available. Wanting a driver's seat to replace my old school OG jap race seat, going to re-register the car so need a factory seat. Prices currently seem to go from $300 to $2k for a driver's seat. What's options are there, that's good condition and actually a realistic price? Located Brisbane. Thanks
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
