Hey guys
my r34 is siting like a 4wd and im really interested in lowering it. i only want to lower the back becausae the front is a good height but on the backs my tires a 245/35s so im gonna get my guards flared. All i need to know is what you guys recomend... Like where to get it down, what price im looking it at...... i live in melbourne, much appreciated people
thanks in advance
kyle :)
https://www.sau.com.au/forums/topic/223936-flared-guards/
Depending on how your wheels sit, I think all you'll need is a roll.
PM 180athid on the forums. He does guard rolling and does a very good job. I think he charges about $45 per guard to roll and I'm not too sure what he charges for a flare, but I would guess $55+. PM to get a more accurate price.
https://www.sau.com.au/forums/topic/223936-flared-guards/#findComment-3944031
Rolling guards is just folding the lip that hangs out from under your guards flat against the guard itself. Flaring is folding that lip and continuing pushing the guard out so that the guard is 'stretched' in a way. Rolled guards shouldn't be noticed unless you're looking from right underneath your guard. Flaring you should be able to notice.
I'll try to get a few pictures though just to show you what I mean.
Edit: Alright, here's a picture of a guard before it was rolled,
Here's the after it was rolled,
Here's another of before and afters.
Images were stolen from a user on ae86dc.
Here's a flare, you should be able to notice the difference between these cars standard.
Hope that helps.
Edited by adam-__-
https://www.sau.com.au/forums/topic/223936-flared-guards/#findComment-3944294
hmmm hopefully thats all i need but i want to flare my guards as well
so i need the best places in melb that does it
any one recommend any place with good experience
Which side of Melbourne are you from? If you're from the east, I'm always hearing good things about Micolour in Moorabbin. If from the west, I always hear good things (usually on NS.com) about Primal Garage.
A little search in the Vic Section will give you more information on where these places are located.
https://www.sau.com.au/forums/topic/223936-flared-guards/#findComment-3944300
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
