You dont need more power, youve already pointed that out yourself - STIs are doing times youd like to run with less power.
So how do they do it? By putting it to the ground better than you.
Your bilstein suspension might be decent suspension, but doesnt mean that its good for drag racing.
Go get sticky tyres and set your suspension up for drag racing specifically, and theres no reason you cant run respectable times.
Also - practice. How many times have you actually run down the quarter?
Because I bet people running 11s with mildly worked STIs certainly arent first timers...
  • Replies 96
A person on this forum (he had an STi with a Power FC and a turbo back exhaust, NOTHING else) and he apparently did 12.5 seconds qtr mile, at standard boost! My car can't even do that now I don't think??
WIth the boost wound up on the STi He surely would'e broken into the high 11's, no?
the turbo of STI is quite small, it is smaller than TD05-16G(EVO's Turbo) just a little bigger than WRX TD04L (STI IHI RHF5 just quick spool than it)
according to my expensive GC8 STI to do 12.5 (is his STI MY00 STI? or MY01+?)
coz the turbo of STI at standard boost(14psi) can reach 80%+ efficiency of the total turbo output (IHI RHF5 series character)
MY00 GC8 STI maximum boost can do 18-19psi evenif he tuned the boost up to 19psi, it wont gain more than 20kw at wheel
you will find GC8 STI still can not run into tail 11's probably still 12.3-12.5 after boost up to 19psi
it will f**k up the turbo quicker (IHI RHF5 VF2x or VF3x is not good for high boost excludes VF22 which can up to 22psi)
a GC8 want to run into tail 11's still need to upgrade turbo(IHI RHF5 VF22@19psi) or keep to take off the interiors
when you upgrade to VF22 but still can not run 21psi coz engine will blown quicker
so it will need to make EJ207 bottom forged than it is possible to run VF22@22psi ....
then you will find fuel system is not enough to support so it need to upgrade injectors and fuel pump
for next moment, you will find high power output to f**k the gearbox up .... damn
finally a lots problem surround GC8 STI evenif GDB STI ... it costs no cheap to modify a quick STI nearly to buy a GTR
the all of GTR are designed to endure high power output, engine, gearbox, fuel system, intakes ... exclude factory turbos :P
Edited by shawn.szutu
You're right, if I set up my suspension for drag, and get some thicker & sticky tyres, I should be able to do low 12's.
ONly problem is, my car is already high at the back, and when it squats down from the torque, there is alot of negative camber and wheel spins like crazy. FOr this reason I purchased a camber kit (whiteline) to throw in some more positive camber.
should I get coil overs to lower the car more so the car doesn't have that much sqaut and then put the camber in? More of the tyre will be on the road that way?
Edited by Turbz RB-25
Just dial in 1/2 deg positive camber on the rear, that will combet the squat. Rex'x may run fairly good 1/4 times, but i cant see an 11. However unless you launch them with big revs and drivetrain abuse, they really feel slow, the in gear acceleration is where you would have him, just dont expect to see him off the line. Why not try a friendly rolling start run on a deserted(private) freeway, say 40-140km/h ill bet you win.
sorry for late response to this thread. but here is an interesting video on youtube.
and on shitty tyres. 340kw. overtaking evo's on the straight and keeping up on the corners.
i have also seen a track race video on youtube in japan with 6 cars. 5 of them GTR one of them GTS-t all of them heavily modified and the GTS-t came second.
so really. buy some Toyo RA-1 semi slick street legal track tyres. they hook up in first gear even with over 300kw as long as you don't force it too hard. pineapples, coilovers etc etc. and practice launching. i reckon those guys with those STis are full of shiet. evidence above speaks for itself.
and you are from canberra. consider BD4s in sydney they have done this skyline
http://autospeed.com/cms/A_2923/article.html
without spending big $$$ on forged internals. don't listen to people in these forums if they say its not possible to make over 300kw without redoing bottom end. BD4s would know they do this shiit for a living.
just a though for your intention of reaching big power figures at a lower cost. i really think however you need to sort out your tyre setup. those Toyo RA-1s are 500 bucks a pop and well worth it from what iv read. read some reviews online people using them for autocross and other events. getting a good 10000 kilomotres on them hard driving too. they heat up real fast super sticky but last much much longer than people think for a semi slick street legal tyre.
Where can I get these TOYO tyres from, and will they fit on my 17 X 7.5 inch wheels?
Cheers
  • 1 year later...
anyone have any opinions on the FALKEN RT615 tyres? Thery are ncie semi slick, 950 for all 4!
talk about round and round information! as stated any well setup skyline gts can match a 4 wheel drive car! if you can drive! i have a 304rwkw gts and constantly run high 11ins with crapy nangkang 265/30/18 they hook up great and its always a treat to watch jaw drop when racing rex and gtrs. tien coil overs camber adjustment kit and practise, and you keep comparing a rear wheel drive to all wheel drive. always going to be a land slide win i must admit. but great fun to caurse an upset! and do you know how many people out there make huge claims and are totally full of it. and there might be truth to claims of low horse power wrx doing fast times but only a few runs then SNAP! stuff breaks. constant times everytime makes for a fast car. plus rwd you can have fun here and there awd tends to have to be doing crazy stuff to slide around.
Old thread........but now that your awake,
Not putting down 4wd systems, their attributes are real and well known. But what a lot of people forget is that there are many many performance cars out there that are still rear wheel drive and doing very well at it, so I wouldn't be selling and swapping on a whim. It all depends on what you want out of a vehicle and what suits your aims.
with the amount of power you have, you should be able to destory him easily
i would be confident in beating at 190awkw wrx in my 190rwkw GTST
its all about how you drive and getting the power down. get good tyres, practice launching, run good pressure and get a good tune / decent setup
i dont know what gearing is in the WRX but youll find 4.11's in the GTST make it accelerate pretty qiuckly, which is why a mild GTST can beat most cars on the street
11s on a lightly modded STI what a crock!
Mate you will absolutely smash him with your 270rwkw, tell him anyplace anytime.
To be honest I would be more worried about mph not the 1/4 mile time. 1/4 mile times vary soo much depending on your 60'. If thats your thing then fine. But a car with perfect suspension and an excellent launch with moderate power wont be very exciting to drive. Go the high power car with reasonable launch and lots of fun hehe
With 270 at the bags, you should easily see 11s with a set of slicks. Before going the new car/full rebuild/expensive path, go grab yourself a brand new set of MT slicks and see how you go. You would be spinning the wheels the whole strip on street tyres. If you can get it to hook up well you'll see an 11 and a low 11 won't be far away.
And the WRX owners claiming 11s with 190kW are talking out there asses. They are probably more like 230-250 and have spent a shit load more than they are letting on. That is if they are making that power properly.
I think you'd be in for one hell of a reality check at the dragstrip!
The GSTS would come back hard at 3/4 track, but not likely to overcome the AWD advantage off the line.
    • I know this is an old thread but I have a particular attachment to the ENR34, so I don't think additional content hurts. For starters, I agree with everyone here in that the performance of a stock R34 GTR is a pretty low bar and one that you're going to spend a lot of money "matching". Now if you're willing to deviate from that template as your goal, you'll be much better off and enjoy the car much more. The engine in the NA R34s is a real kick in the nuts in terms of upgradability compared to previous generation NA cars. The NA heads on the RB2X NEOs have MUCH smaller intake port cross sections and are not compatible with any of the aftermarket forward-facing manifolds available for the RB25DET. This can be remedied with a RB25DET NEO head, but those are expensive relative to what they are. A full long-block from a turbo AWD Stagea is generally a better value and will run you about $4000 USD to get it to you. This will get you the stronger RB26DETT rods, as well. That would give you a base to build off of to be safe in the 400whp range. Not shooting for the moon, but if the stock R34 was your bar, this engine would buy you enough to be just North of stock GTR power. A forward facing manifold would allow for the easiest method toward using Bosch EV14 format injectors such as those from Injector Dynamics and FIC, to name a couple. People hate them because they're copies, but Greddy fakes can be had for around $300 USD. With what the fuel rail, regulator, injectors, and the rail adds, figure $2000 USD for the whole setup including the manifold. With the OEM brackets and a bit of trimming to the ends of the lower frame rails, the OEM intercooler mounting brackets can be used to mount an OEM GTR intercooler, or an aftermarket one made for a GTR. Those are handy vs a universale due to the angles that the end tanks have on them. Then your plumbing become super straightforward at that point despite having to cut a hole where the battery is an a matching one on the other side for the pipes. Battery can go to the trunk. I'd round up to a healthy $2000 USD here too (maybe even a tiny more) to allow for a nice aftermarket unit and some pipe fabrication. Or if you can find someone that's upgrading to something larger, the used market comes in clutch here for a decent savings. I won't even get into turbo sizing as that's something that would be for yourself to determine. HOWEVER, for the purposes of your stated goals, a Borg Warner 7064 with an internal wastegate would be a perfect spooler and would make stock GTR power easily. It would also bolt up to your OEM manifold (that would come with the DET you purchased a couple steps above) if it were ordered with a T3 flange. More with adequate fuel. If you can stick with the OEM exhaust manifold then expect to be in the whole about $6000 USD for decent turbo like the one suggested, a down pipe, new O2, and full exhaust to mate up, and upgrades to the integrated BOV in an EFR or a standalone BOV for a different turbo, as well as an aftermarket IWG (internal waste gate). Those last two are definitely optional and unnecessary. All of this stuff above does you no good without any way of tuning and or monitoring the engine. Bite the bullet on a standalone engine management solution. If your experience with wiring is limited, you're going to have to hand it off to someone else, though. Unfortunately, the adapter/patch harnesses available are typically made around the GTT which does not include AWD, and the GTR, which integrates into a lot of chassis features that aren't present in your wiring interface. So the ENR34 is the oddball. So you'll want to expand a bit on your selection and find an ECU that's capable of running the ATTESA pump also. I have a Link Thunder, but you don't need quite that much ECU to accommodate that. You WILL need someone with the know-how to tune it and code those features into whatever software it uses. And to wire it up. This will be your most significant expense. Call it $6000 USD with an ECU, an okay wiring job (no motorsport grade at this price), aftermarket triggers and R35 coils, and the time it takes to tune the ECU with added features (electronic boost control solenoid, MAP, IAT, the new triggers, and ATTESA) and don't be surprised if it's more if you want better work done. Grab a clutch made for any RB pull transmission R32/R33GTR made for the power handling capacity you're looking for. Budget $1500 USD for a new good one. That's about $20,000 USD for an engine you've upgraded yourself and had wired and tuned by someone else. That's no brakes (ENR34 brakes are pathetic), suspension (again, pathetic), or wheels and tires. So you're pretty spot on in terms of spending $30,000 USD extra on the car just to get it to perform a little better than a stock R34 GTR while looking like a bone stock ENR34 with some wheels and suspension mods. That doesn't include fluids, maintenance items, gaskets/seals, repairs needed or anything else discovered along the way. But you'll have a car you can take to the track and have fun without worrying as much about nicks and dings.
    • Okay so, please read this. car started and ran fine. got my tuned ecu by RSenthalpy, did a bunch of pulls to test it out and finally drive the car after half a year of it just sitting and idling at most. Everything was good, thing ran flawlessly and had so much power, didn't feel slower than a Prius anymore. Parked it back and turned it off.  Next day, I install an AFR and start the car. Didn't wire anything to the ecu. Just gauge.  Car started, but died out in about a minute. I figured it was cause my car was on a lift and the fuel was really low and old. I add 5 gallons of fuel, still cranks but no start. I remove all AFR wiring (tapped into double din acc and power wires but there was a nest of wiring there so I was worried I messed something up. tried to put it back to how it was prior to afr install.) Still cranks no start. Changed spark plugs with brand new ones Changed fuel pump with a new one (verified working) Did compression test , compression came back all at 150ish. All fuses are good, Relay seemed good but ill double check by switching similar relays around. Verified MAF is working - Ended up getting curious as to why fuel pump is not priming when ignition is on, so I cut the fuel pump ground and power and connected them directly to a portable jumper. I also disconnected fuel line to fuel rail to verify fuel is being sent. So with direct jumper power, the fuel pump turns on and shot gas everywhere through the fuel pipe that I had disconnected, so ny doing that, I verified no clogs in fuel lines or filter. - Tried starting the car with that jumper directly wired to power and ground, but car still did not start. I'm guessing its a CAS issue but im a little scared to check it without messing up timing or anything else since I actually dont understand how to check CAS lol. If anyone has any other suggestions or recommendations , please let me know.
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
