+1. Awesome shots Penny!
Were they taken sorta behind Hewett looking towards Green Valley or whatever that is called there?
Cheers!
They were taken at the end of Cheek Ave, just down the road from my house. Hewett is over a few hills to the left.... probably the same valley tho!
I also found a cool church in Gawler but those pics didnt turn out as good, with the right camera and lighting it would make a good spot!
Finally gave her a good wash and took some pics on Sunday, these would be my favourites :P
decent shots penny, hey check your samsung camera out .....its setup for night shots in your photos in case you didnt notice it ?
How do you know!?
I took pictures on every setting on it and then picked out the best ones from the lot. Im not very good with my camera but If i shoot on every setting then I can normally get a few goodies.
Cheers!
Yep I know where you mean now. Close, but no cigar lol.
Ive wondered about shooting infront of that church before, definately some potential there.
edit: another really good place I rekon would be in front of the Cheateux Barossa, because its such a massive building thats decorative etc. Or ask the owners of Para Para Mansion if you can park it in front of the house....
Edited by dark.sky
How do you know!?
lol I have utilities that looks at the code of photos to see all the settings of the camera , all EXIF data... it showed up as your camera is on night shot mode in at least 2 photos ? but it looked like daytime in your photos..?
Edited by sapphiregraphics
It was daytime, I just tried every mode and these looked the best.....Weird.
Its only a cheapy camera, one day ill fork out the bucks for something spesh but my method of taking heaps of photos on all different settings is working out alright for now. Haha
hey what ever works for ya...they look decent enough anyway
Ive seen and taken some great shots on cheap cameras. so its not always the equipment cost
hehe I'm very tempted to, especially after seeing the matte black 33 in action at mallala yesterday... looked mean as!
indeed, that car is sex
and it was the same colour as yours beforehand too marko
Was about to pull in my drive, looked up at the hills and just had to :) pity i only had my phone on me.
Pretty cool photo dude, half expect to see the reaper or something coming throught the fog! lol :D
p.s. is that your driveway?! Bogged much! :)
great pic, imagine if u had a good camera on ya
This is my fave! Taken on one of my favourite road in the hills...
love the pic.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
