Looks killer Stewy! Looking forward to seeing you do well at Matsuri also!
Nice ride there Jake! Welcome to the SAU:SA Club! Did you see our display last week at the Kadina Show'n'Shine? We had 10 or so very nice Skylines there.
hahaha thanks mate!! nah i was in adelaide that weekend lol i knew nothing of that show and shine .
let me know when ya all up this way next. go for cruise/drinks/food ect.
  On 22/06/2011 at 1:41 PM, nisskid said:
It's hard to say an actual price, i got an absolute deal on it though, i spent a fair bit of misc costs on it, but under 7k.
Fair enough man.
Did you end up emailing the old owner pictures of it all bent and and cut up in the container? lolol
  On 26/06/2011 at 12:34 PM, Weezy said:
Fair enough man.
lol i really need to get his email off streeter. the only issue is i dont wanna get streeter in trouble, as he was the go between for me and him.
  On 21/06/2011 at 12:59 PM, Munro said:
3500kg tow capacity - great for towing race cars!
And spending more time getting fixed then driving! mates uncle has one of them, reckons its nothing but trouble... Maybe he just got a dodgy one haha. Nice car but.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
