cheers DC. yeah that was from last night, Josh had his 33 out as well which was doing mid 12 also, his is much better to look at than mine though.
Was hanging out to do this, got some Nitto's off MattR not long ago but just have too much and have the Time-Attack coming up on the 11th June (pending weather) - and a little weary with the gearbox/drive-train prior hence had to make late decision to miss it :( plus it got shifted from original date which was the killer... but great time and that is a good reaction time as many have noted! Can hardly wait till the next one!
Only photo Ive got until Lukey puts some up from the drags, tell your Mrs thanks for the pic nelson.lol
Managed a best of 12.7 @ 120.1mph, 2.5 60ft. has the power, just need the traction, wasnt too keen to drop the tyre pressure too much with cheap 235s on a 9.5"rim. I know this isn an ideal drag set up, but i was keen to know what it would run how i drive it everyday on the street with no changes. I think ill attend the july 1/4 with some drag radials and stock suspension to boot.
I just looked through my timeslips and my best 60' in the S15 was 1.902 - and sadly that wasn't on my fastest run. I never ran on drag radials - I now wish I had tried some back in the day, as I always spun some through 1-2 and 2-3 gear changes. Helps that the S15 was only 1,250kg too :)
^^ Someone changes their rims....Look like Enkei light-weight :P Good to see 3 skylines in the same pic
Thanks again DC
Would be good if more imports go out, i was getting tired of the big blocks passing me on 2 wheels :( Going to get some prices on drag radials soon and pretty sure ill be out for the july street meet.
The enkeis are sweet, aggressive stance on it looks awesome.
Luke has his pics up, there are a few of yours.
  • 2 months later...
Haha harsh, I didnt know that threads in the SA section meant that others were unwelcome??
I obviously posted my other car in here a while back, and this was still in my "my content" list, with a new post, therefore I posted my recent aquirement
Go ahead and delete it if it is that much of an issue :s
Nah it's not an issue mate - I was just wondering how anyone from another state even found their way into the SA forums, that is all. And I did say your car was pimp :)
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
