Favourite Photo Of Your Car!
J - Rad
Thanks guys. :closedeyes: It's just an Evo 6 GSR (not a TME), so it has all the luxuries.
What kind of times did she do ?
It posted a 1:04.5 in it's first outing at Wakefield Park in June (at Evo Nationals) and it ran a 1:13.5 at Mallala last month at the Autosport MGEC Time Attack.
Who built it out of curiosity?
built buy browns engineering in QLD, bored 40 thou new endurotec pistons, moly rings, king race bearings, prepd rods, crank collar fitted, rebuilt head ported new seals, lewis drain back kit, head welded n tap'd for vct, new 25 water n oil pumps, not sure if its worth putting arp rod/head bolts and a metal headgasket in or not, will need another manifold for my 3076r
I ended up going with ARP rod and head bolts. My intention was "whilst its all apart you may aswell". Shame it ends up costing a packet though!
IMO RB25/30 + GT3076R is the best combo for a responsive ball tearer combo. The midrange is obnocious!!!
  • 4 weeks later...
yer mines all assembled.. but not sure since its dry to turn her upsidedown and stick some arp rod bolts in her just for piece of mind, head bolt nissans are usually ok, and wont be running a40psi, hopefully have front end done (this is a s14a btw) and engine test fitting over the chrissy break aiming to be on track mid next year.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
