hi guys,
im getting the trust/greddy timing belt kit which includes the seals & bearings...has anyone changed their timing belt themselves on a gtr???
ive been contemplating whether i do this myself or not, ive changed timing belts & timing chains on my previous cars which was simple (make it top dead centre etc) but not sure if i should do this myself being a gtr - am i going to run into any problems if i do this? im assuming the crank bolt will be super tight - im also guessing the radiator etc needs to come out for accessibility.
ive got the workshop manual to check tolerances, torque wrench & other tools required.
i also had it tuned so im worried that the CAS might be out when i put this back on, can i just mark it with pen & put it back in position??? will the new belt also change my cam timing??? last thing i want to do is destroy my tune after spending a good amount to get this right but if its as simple as swapping over the belt & putting the CAS back in the same position im happy to give it a go :P
thanks guys,
https://www.sau.com.au/forums/topic/223955-changing-timing-belt-on-r32gtr/
the cas is easy, if its never been touched before, when you undo it you'll be able to see where the bolt was originally, otherwise just mark it with a permenant marker or white out if you're worried.
The crank bolt will be very very tight, but you will also need a harmonic balancer puller because its pressed on, other than that everything pretty straight foward if you're good with turning spanners. If it was me, i would also replace the water pump while everything is undone.
Just remember make sure everything is absolutely spot on with the belt, these arent a free running engine, the valves and pistons WILL HIT if it jumps too many teeth.
Goodluck
hi guys,
thanks guys,
im still not sure if i do this myself - anyone here done this themselves? i do need to make a harmonic balance puller
hi marko just get the thingy and turn that over, move the whatsy to the left, fill the jibbtipop with the best you can find,don't for get to take a break buy the best meat pie you can get have a vb for strengh and a power nap then get to it again with a long look a phone call and a scratch of the head then put it together again and give us a call when the tow truck comes to pick it up.....................take it to Mr it will be all right and tell him to set it up the same as he took it off or if your worried take it to Mr personality.
LOL - nothin like a "Fourn Twenty" & Vitamin B, they dont know what they're missing out on!
mr 'dont worry about it' is doing it for me
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
