i put in a new steering wheel and boss kit. as i locked the hicas i took the steering sensor of while i was at it. the car was feeling fine then all of asudden the steering went really heavy and slowly got lighter as i went on.
what can i do to fix this??
oh and the sires to the sensor kinda had a run in with the wire cutters :woot:
https://www.sau.com.au/forums/topic/223985-steering-probs/
