Hey guys,
is it possible to merge my old username and my current one into the one profile, so that my join date and member no reflects how long I've actually been on the forum etc etc? :P
Stupid question.. but would be good if you could...
Old username was hellrazorette.. want to keep Kaz180
I signed up this new account in 05 before you guys were able to change usernames..
Thanks for the help :)
Cheers!
~Kaz
PS Sorry, I know I'm being a pain in the butt!
https://www.sau.com.au/forums/topic/224027-merge-2-usernames-into-one/
Yeah it's a pretty big change to the database as every post you've ever made and every message you've sent (and things like settings, trader ratings, etc) would need to be changed to point to your 'old' user ID, which could create duplicate entries in tables that won't allow it (because your old account still exists and has data linked to it), and it might cane the database and cause table locks while the changes are being applied. That said I think there's an IPB mod to do it but I'd always be a bit dubious about loading something that makes that many changes to critical tables without doing some pretty extensive testing first. Things like your join date can technically be changed quite easily, but changing your ID # (ie 19275) is where the problems start.
So yeah, short version... unlikely, sorry! :laugh:
    • Give it 40psi and send it to the moon
    • I suspect 550s are on the large side for happy operation with a stock/Nistune RB20 ECU. The Hitachi ECU doesn't love short pulse width operation, and the RB20 doesn't need much fuel at idle. Big injectors can be unpleasant. This could be contributing.
    • Yeah, I still don't know why the idle speed control can't catch the falling RPMs. In the Consult logs I see the AAC duty cycle rising, but suddenly it goes lean and the engine stalls. Anyways, the relevance here is the DW 550cc injectors are probably the same. So if OP has similar issues I would be tempted to finger those injectors as problematic for whatever reason vs the ECU failing for some reason.
    • Yeah, sort of blurring two different things together, aren't we? I just meant O2 feedback closed loop. I used to have a 0-1V LCD meter on my dash, wired directly to the O2 sensor signal. So you could easily see what it was doing. Normal running it would flick back and forth nicely. Slow down to an idle and it would keep flicking, as the ECU tried to servo to maintain stoich, but it would slow down as each swing happened until it would stay at one end of the scale. As I said above, the sensor heater is not enough to keep it hot enough when there is also little heat in the exhaust flow. Give it a blip and it would start swinging again, then peter out again. Meanwhile, idle speed control would run just fine, because unrelated.
    • It's not even O2 feedback, it's just simply when the ECU sees the closed TPS signal for whatever reason the idle will start steadily dropping until the engine dies. With the TPS adjusted to not trigger closed TPS it will idle at some ridiculously high RPM and something like 6 degrees of timing. In the absence of getting eyes on it personally and a lot of quality time doing diagnostics I couldn't tell you what the real problem was but it was interesting nonetheless
