  • Replies 40
Hi Rekin,
Yes AutoTechnique is their co-business and it does look they are a Holden/Ford shop but they have informed me that they are moving into the Japanese car market.
This is the first year we are using them for the Dyno. They have a pretty good set-up with Plasma and Sofas for the Dyno etc.
Even if you dont end up Dyno'ing your car, come down for a watch
cya
Bran
I think it will be great to come down.
I printed the flyer off today.
I'll probley come down and spectate, take some photos, get some BBQ and drinks ;)
The Dyno day at RE Customs was kick ass! Big turn out.
For sure everyone is welcome.
I am not sure how big of a turnout it will be this year as I seemed to of chosen a date just after a few Dyno Days have just finished :D
Sure man
I try and spread the word and get afew ppl down to spectate and dyno if not already done at the SAU Meet Dyno Day at RE Customs.
Sure man
Thanks buddy. Appreciate it!
I might come down and put the car on the rollers.
is there likely to be many big numbers cars there?
Well a few years back some of the GT-R guys came down like Snowy, Frank and Ferni they had some great numbers but this year Im not sure.
This year there is an BMW M5 coming, M3,
An Audi RS4 is still tentative.
A C63 AMG Merc is also Tentative.
If the Evo X is released before the 5th then there would be an Evo X coming.
This year there seems to be a lot of clashes with other things .. a lot the regulars are not coming :ninja:
So ... Hard to say guys but I hope so :P
wouldn't mind seeing how the power of my car is on another dyno with new plugs and cleaned throtal body
Its a good way to see how the car is running.
i always see monaro's parked outside the place, so im guessing they will also be attending hehe
Yah they probably won't be. But we are deciding on a car to be a Mystery Car for "Guess the Kws". Raffle
The WRX club sprint at Calder has now been canceled. Might pop down Brandon ;)
Yah if you are in the area pop down.
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
