West: If you are 100% sure you are coming you can pay on the day.
But please email me your
- Name
- Vehicle/Year/Make Model (whether it is a RWD/FWD or 4WD)
- and Mobile Number
Thanks
Can i pay on day?
Will PM you my details.
Thanks
  • Replies 40
Love the pics!!
2 photos of dad's gtr :) thanks!
He is pretty happy with what he got on the dyno.. did anyone beat 300kw??
Hey Lauz!
Yeah there was a lot of impressive cars there.
You see the Red 300ZX, No. He hit 291 kW, but before he came to the Dyno Day, he just got it tuned and hit 320 kW at another workshop.
The Yellow Evo 9 just hit 291 kW.
RE Customs R34 GTT (Matt) he hit about 300 kW for the 3 runs then his 4th run, they up the boost and hit 410 kW.
And as you know Lauz, your dads GTR his 300.7 kW. Did he get a prize? LOL!!!
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
