West: If you are 100% sure you are coming you can pay on the day.
But please email me your
- Name
- Vehicle/Year/Make Model (whether it is a RWD/FWD or 4WD)
- and Mobile Number
Thanks
Can i pay on day?
Will PM you my details.
Thanks
  • Replies 40
Love the pics!!
2 photos of dad's gtr :) thanks!
He is pretty happy with what he got on the dyno.. did anyone beat 300kw??
Hey Lauz!
Yeah there was a lot of impressive cars there.
You see the Red 300ZX, No. He hit 291 kW, but before he came to the Dyno Day, he just got it tuned and hit 320 kW at another workshop.
The Yellow Evo 9 just hit 291 kW.
RE Customs R34 GTT (Matt) he hit about 300 kW for the 3 runs then his 4th run, they up the boost and hit 410 kW.
And as you know Lauz, your dads GTR his 300.7 kW. Did he get a prize? LOL!!!
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
