Currently I have no audio in my car, so going to install a new system in the next a few weeks or so, but I've got a few questions.
1. What is the stock front speaker size in a 32GTR? And what is the biggest size I can install without stuffing around too much.
2. Going to install coaxial front and rear, since I couldn't be bothered drilling hole for splits and mounting the cross over. So what is the best 2 way coaxial
on the market money can buy?
https://www.sau.com.au/forums/topic/224046-32gtr-audio-upgrade-questions/
hey man, um with the size of the speakers in the gtr im not too sure. but just get urself some spacers made up, they are REALLLY easy to make and this way u can fit wat ever size speakers u want, preferably 6.5"
with the "best coaxial" on the market try post this in http://www.mobileelectronics.com.au. um also because audio is a very subject and personal choice might be best to go and hear some speakers urself at an audio store. this way u can judge urself what speakers are better.
I ended up putting in some 5 inch co-axials in the front ( I think they are 5inch). I just made a little spacer out of some MDF to mount them. throw out the old plastic speaker mount thing and just make one up out of some mdf. easy, and no need to cut up the door trim or grill. for the rear I just slotted in some 6inch co-axials (i think 6 inch, may have been 6.5). either way it's pretty easy.
no idea what are the best money can buy is, but if you are willing to spend up decent coin maybe just get some splits? it's not that much more effort to mount the cross over and tweeter. I really like boston accoustics and have enjoyed their splits very much in previous cars, but listen to some speakers and choose some you like.
As Chris said, but Im running Alpine Type R 6.5 coaxial up the back, and the same in 6.5 splits at the front with a spacer (easy work)
Theres a template in this section somewhere for this.
Speaker choice will come down to personal preference and type of music you mainly listen to.
But I personally love mine, and I havn't even got around to sound deadening yet.
awesome!. Thanks for the input guys. :)
Its not so much mounting the crossover that bothers me, rather positioning the tweeters so they can produce overall package. Being down that road in my previous car, but didn't really sound good with tweeters mounted on the door. ;)
yeah I can unserstand that. the tweeters really need to be mounted high and foward I think to get good sound.
in that case just go for something similar to what I did. it's not earth shaking, but I just wanted something for long drives and the main thing was it had to be lightweight, so no amps, and speakers as small and light as possible.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
