FS:
Drag Me s13.
rb25
hks head, cams, cam gears, belts
greddy inlet + 90mm throttle body
greddy t78 + manifold
tial 44mm external gate + screamer
trust 6 speed dox box
motec ecu
nismo 740cc injectors
spitfire coilpacks
trust oil cooler + relocator
100mm thick cooler
turbosmart supersonic bov
1500hp npc custom clutch
1 piece tail shaft
tomei 2 way diff
twin thermos
full kit, front, rear and sides
fiberglass vented bonnet + sparco bonnet pins
fiberglass bootlid + adjustable wing
vented wide front guards
hid 8000k headlights
nismo grill
clear rear taillights
ganador blue lens mirrors
driftteks
5 stud brake upgrade with slotted and drilled rotors (front brakes massive)
jic fully adjustable coilovers
custom dash cluster, pivot stepping tacho blitz blm boost/water gauges
black avcr
bride drivers seat tenzo adjustable passenger seat + 4point harnesses
cucso 7 point roll cage
rear strut brace
bosch external pumps + walrbo feed with surge tank
battery in boot
zex nitrous (not used)
Car is making over 400hp on 1 bar boost. Mod plate for motor, turbo and gearbox.
$22000
Car is in regents park, QLD
Chris
0402 551 209
**For the last time, no i do not own a black skyline. I purchased these plates when that skyline car was de-registered, however original owner is buying them back hense why car will not be sold with them**
https://www.sau.com.au/forums/topic/224073-fs-drag-me-s13/
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
