Hey guys
i was just wondering if anyone knows if it is difficult to install the rear boot lock??
as mentioned some shmuck helped themselves to my badges.
I have a "96" r33 gtst and the rear badge as you all probably know covers the lock,
which they took as well.
also can they open the boot easily now?? i have an alarm that will go off if they do but i'd prefer to keep
people out the old fashion lock and key way.
when i change the lock can i change the internals to fit my key or am i destined to roam the streets with
two sets??
Thanks in advance guys.
Gordon
p.s. if i happen to catch the little bastards and break their hands, does that make me the criminal?????? :D
https://www.sau.com.au/forums/topic/224088-badged/
lol... i'm guessing they ripped the swivelling badge off your boot lock right? how does that make it any easier for them to break into your boot? LOL.. when all it does is cover the boot lock.
imo i'd leave it.. my bet is you'll go through the hassle of changing everything
then the same punks will laugh and come and badge it again...
https://www.sau.com.au/forums/topic/224088-badged/#findComment-3946364
I'm no judge or anything, but sounds like fair justice to me... Wait, is condoning violence bad..... :)
https://www.sau.com.au/forums/topic/224088-badged/#findComment-3946458
they took the entire lock mechanism and theres a big gaping hole in my boot lid!!!! i'll have to do something about that!!!! lol
https://www.sau.com.au/forums/topic/224088-badged/#findComment-3948655
Weld up hole & repaint... looks great on my 32R
I'm doing this too - whilst getting my d wing installed and whole boot resprayed.
Mine didnt get badged, it actually snapped off one day when i went to open the boot up and chuck come groceries in :)
So atm im left with the bare boot lock/keyhole. It looks ugly and unfinished without the swivel badge...
https://www.sau.com.au/forums/topic/224088-badged/#findComment-3949103
to install the boot lock is pretty easy mate just push it into the hole and there should be a slide to go in too that holds it in place, not much to it really. but as said id deffo go for the debadged look and im on the look out for a carbon bootlid that will allow it :P
https://www.sau.com.au/forums/topic/224088-badged/#findComment-3951798
i just bought a lock and hopefully get it next week.
that clip must be the thing rattling around in my boot lid.
if i dont like the look i might weld it up.
i dont understand the alarm part? i have a mongoose m80. is that an optioon with the alarm???
https://www.sau.com.au/forums/topic/224088-badged/#findComment-3952003
My R33-S2 came with a "well, it looks like someone wanted to steal the badge" look so i replaced it with a S1 version. The lock internals can be removed and installed to the new lock holder as it's only clipped by "C" clips so my main keys can still work with the replacement trunk lock.
https://www.sau.com.au/forums/topic/224088-badged/#findComment-3968944
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
