Anyone thinking of having a crack at this event?
My RX7 might be be finished around the time, but keen on running the GTSt just for fun.
Pretty good value at $645 and all run out of Launceston for three days with hillclimbs, circuit sprints, autotests and navigation trials all part of the game.
No roll cages required, just normal club day/hillclimb stuff like CAMS L2S licence and couple fo 1kg fire extinguishers.
SAU team perhaps?
  • Replies 48
pretty similar to the dunnon, it's a little more weighted to the driver than combined efforts (for the super sprints, and hill climbs). but there is still a resnible about of time matching stuff
i'll be in it if i can get the $$ together. someone has to try and knock streety and stu of their purch :banana:
will your dad be sitting passenger?
ive wanted to do this for the past few years. didnt have the $$$ the first time then didnt have a car last year.
id really like to get some temporary rego for the drift car and come put it through its paces. my partner is also very keen to get into it.
the crew i was with during targa talked about it a lot so i reccon i can get some help from them.
SAU team would be grate.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
