Follow the bottom radiator hose to the block.
Remove the hose. There will be a thing with 3 bolts that the hose attaches to.
Unbolt it and you will see the thermostat. Give it a tug and remove it.
Clean up the hole it came from, install the new one.
Reseal and install the flange.
Refit hose, fill with water and bleed.
ultra blue is great stuff. i used it on my water pump (with fingers tightly crossed cos it was my first mechanical work) and my exhaust joins - all are perfect.
when you 'clean up the hole it came from' use a razor (if there's sealant still hanging there) and/or some light sand paper.
i'm doing this on the weekend, if i think to do it, i'll take photos - it looks like a bitch to get to the housing bolts.
Most R33 doesn't come with a thermostat, my blown engine and the replacement engines doesn't have one either. I bought a Nismo thermostat and it's installed on my current engine. Most of my friends and replacement engines also doesn't come with a thermostat. I don't even know what the OEM thermostat looks like. lol
RPR33, Check your radiator and hoses. If your temp gauge is going up, then radiator is your best bet. Mine recently sprung a leak and cause the temp gauge to go skyrocket. Now i'm using a Koyo OEM replacement and my car works like a charm now.
Edited by teng
Hey guys I just wanted to know how to change my themostat on my r33 s2. the thing just isn't heating up!!!
rb30 thermostat is direct fit replacement. all cars should run one, my car sits at 76 degrees with my rb30 thermostat and the PWR radiator.
as for R33's - yes they should all come with thermostats - someone removing them for some silly reason. doesnt help the car at all to remove it.
    • I think you're missing the point here Duncan, I was trying to say that if you want to go fast around and have a spare $80K to $100K, easiest option is to just buy another car instead of modding your Skyline. Sure blowing $80k to $100K would make it fast, but then you'll have a car that you can't drive on the street comfortably. But use that $80k, buy a fast factory car, spend like $7K on AliExpress pipes, email tune, tyres, pads and you can be fast, not to mention now you have two cars.
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
