hey guys im lookin at doing a 30 bottom end in my car .i have a defect sticker on the car now and the current rb26 is too modified to pass because of cams and ecu, so i bought a low compression rb26 complete engine and wanna build a 26/30 with low mount turbos im just wondering could i plug in a stock gtr ecu into the factory gtr loom and it run the engine fine? i would use stock injectors as well, does anyone have any idea if it will run well and drive smoothly enough to pass an inspection? i dont need an emmisions test or nothing but they will drive the car and it needs to drive along in a normal fashion.
If not ill have to stick to using another rb26 bottom end and build that :)
After building my rb25/30 my mechanic turned the key using the old rb25 tune (wolf3D). The car started idled without issue, but not sure if it would have driven, i pretty sure my mechanic would have drove it on the rollers, but he wouldn't have driven out out the garage.
You would probably have better luck, fitting std injectors to your current rb26, fitting all the std bolt-ons and using your std ecu. Provided your cams aren't ridiculously lumpy, it should run fine.
the cams are pretty big, bigger than 272s and higher than 11mm lift so they are not easy to hide ;) the turbo is a big single and that doesnt help the looking stock factor lol.
i might give it a crack getting this engine over with my current ecu and hope to christ they dont pick the cams and ecu
thanks for the feedback so far guys
If you run the stock afm`s/injectors/cams it should run fine onthe stock ecu. It will just "see" more air and adjust fuel accordingly, as long as you dont cane it too much it should be sweet :)
on the 26 ecu it will be fine for driving around.
don't go thrashing it as the timing map will be completly different from the 26 to the 30 due to extra capacity and comp ratio
great info, ill see what happens at the inspection with the current setup and that will determine which way i go later on with this new engine :P i want a single turbo rb30 or even rb30 with twins if i have to, but rb30's are illegal in a 1996 model car and single turbo might be an issue to, but ill find that out with my current setup. I also have 4wd so making it work with the 4wd sump is also a drama.
The normal rb26 with some forgies and low mount 2860-7s or even -5's looks like the best "legal" option but not what i would really like :ninja:
Edited by unique1
I don't know who told you RB30's are illegal but they're wrong.
Putting an older emissioned engine in a newer car is illegal but changing bottom ends and retaining the head/emissions setup for that particular year/car is fine.
If you want some help/advice in regards to 4wd RB30 then give me a bell and I'll take you to see my mechanic mate. I have his old 30 and he built a new one to go into his GTS4.
If not ill have to stick to using another rb26 bottom end and build that :banana:
I have done this it will run fine. I have done everything you have done to a degree, (with your past and current cars) I will pm you more details or offer opinions if you like as I dont want it public ok. just shoot me a pm.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
