Finally found a "more" suitable set. 19 x 8.5 +5 dish 80mm front and 19 x 9.5 +12 dish 86mm rear. I also put a deposit down. Supplier assured that i need rolled guards 5-10mm but nothing too major. Im abit uneasy the more i look at the offsets though. Any insight as to what im in for? Any help muc appreciated
LOL u will more than likely need flared guards and a respray once your paint cracks, unless you are planning for widebody forget it
i have spoken to a few guys that flare/roll guards. 5-10mm flaring is not a issue. I have seen cars with similar offset and even wider rims then mine aswell. What tyre size do you guys recommend as i need to order them soon?
buddy the offsets are what is going to make it difficult for you not the widths. you need rims that have a +30 offset or simillar.
the offsets that u sre suggesting are ment for gtrs
Don't listen to these pussy's, the rims will fit fine. On the front you'll only need to roll the guards, on the rear just roll guards with a light flare. On the front just run a 215 tyre (unsure what profile for 19" rims) and on the rear run a 235 (or a 225 would be fine also). Maybe get some adjustable camber arms for the rear while your at it so you can pull a bit of the negative camber from the rears and then flare the rear guards to suit.
Will look pretty tough. :P
dont worry mate i aint listening because i already paid for the rims. I was fully made aware that rolling and faring will be needed..dam gota love the dish. They are in stock too so dont need waiting period from jap either. Anyone else recommend tyre sizes?
Good luck Drgnball. I hope you checked the front wheels are at least standard disk type so they clear the GTT front brakes. Hope whoever you have pulling your guards out do a good job and don't crack your paint. Post up pics once you are done...and don't let us spot these wheels on the For Sale forum coz they don't fit :)
  • 3 weeks later...
Will look pretty tough. :cool:
what you think about 225 F and 245 R?
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
