Item: Nissan Consult interface and serial cable to connect to laptop
Age:Brand New
Condition:Brand new
Price:$100 ($8 extra for postage)
To Fit: Most Nissans (Skyline RB20s Rb25s SR20 VG30s etc...) as long as they are running standard ECU and have the consult interface (usually located near fuse box)
Contact:Damon, PM me or sms 0433 839 629, email [email protected] is preffered contact method.
Comments:
Hi guys,
I've got a couple of extra consult interface cables. I bought one for myself and it was cheaper for me to buy a few extra to save on postage.
The cables are brand new and are really good quality compared the last type that I bought which was just a PCB, these are sealed units and have a proper connector. Doesn't come with software, but ECUtalk is great and a few other free bits out there do the job nicely (i can provide you with some links if needed). The interface comes with a brand new serial cable too which is about 1.8m i think, and will connect up to any laptop with a serial post connector.
For those who dont know, Consult interface can be used to download fault codes from the ECU and get realtime data from the car (RPM, speed, injector duty cycles, water temp, 02 sensors, heaps of other sensors, too many to list, can also give 0-100 times). These cables are a lot of fun to play with!
Im after $100 each, delivery is about $8.
Cheers
https://www.sau.com.au/forums/topic/224225-nissan-consult-interface-cable/
Yeah, most have them near the fuse block on drivers side. Seems to be a bit difference from year to year. I know on my 94 R33 GTST its a white connector (14 pins) right near the fuses under the steering column. Apparently nissan started using these from 1989 onwards and cover most models.
  • 2 months later...
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
