Hey guys,
Having a cruise for my birthday!!
Its been a while since i've had one of my cruises but hopefully this will be a big one!!
WHEN: 5th of July
TIME: 8PM for a 8.30PM Leave
WHERE: ESTA PARK CARPARK
The cruise will be a pretty big route, maps will be provided of course!! Heading to north and south, Hills run at the end like everyone likes it! Trying to get drink and food provided also, trying my best hehe.
Everyone invited, just let me know if you will be going, muchly appreciated!! ;)
xox kahli xox
Edited by Lil Miss 33
https://www.sau.com.au/forums/topic/224226-kahlis-birthday-cruise-5th-of-july/
  • Replies 300
Hey Kahli,
Definitely going, as long as I get a ride to take some good pics!
Should be mad, around my birthday too.
Talk bout it later.
Tom.
PS: Here's my photo album if anyone is interested.
Ill be ther Kahli, in all my white goodness. Oh and i noticed a bulletin about it on myspace, i wouldn't be going too crazy, you might run into some unwanted guests, and not police, i mean local commonwhores.
Edited by Damo_R34
Ive always done it and its been fine. I will be noticing the cop station around the corner of my house that it will be on. I do it everytime and have had no trouble
Notifying* ;)
Dont worry too much Kahli, im sure it will be all good!! Cant wait
Lol I think he's referring to the typo, look closer.
It says 'Esta' when it should be 'Etsa'.
Oh no, I've said it too much in my head, now it just sounds and looks weird!
It'll be sweet though.
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
