Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh well you see that ummmmmmmmmmmmmm yerrrrrrrrrrrrrrrrrrrrrrr but they WEEEEEEEERRRRRRRRRRRRREEEEEEEEEEEE just so GOOOOOOOOOODDDD!!
  • Replies 300
Pete, Leigh said he would be very happy to wash your bike for free!
Careful, careful.....I might hold ya to that!! :D
NOTE: If you wanna wash your car or get my mates to wash them for you (note you have to put the money in the machine haha)tomorrow i reckon we should catch up at the new BP on Port Rd :) 2PM! WASH YOUR CAR DAY!
I have to do mine in the morning because of a mates wedding tomorrow arvo otherwise I'd probably join you
well dstroy, jenkies, damo, min are all meeting at mine tomorrow night to go to the meet spot and thats all sorry then me and damo's new girl are going to hq so we will be all dressed up lookin hot and stuff
Mmmmmmmm ... hot women! :D
Good luck to everyone going - every idiot and his dog is going to turn up to this one, and it is going to be wild. When the cops get involved look out.
Yeah thanks for the support Andrew, we will see how it goes then you can start criticising!
hehe I was just having a friendly stab :( .... we get along just fine :D
I am still under the impression that Kahli didn't take the advice of many people's posts in this thread to change the meet spot from the MySpace advertised one. If that is the case (which I think it is) then it will be an interesting cruise. That is all :) .... didn't think I was being particularly negative - I even wished you luck!
how many stags are going to be at the meet tonight?>
1 ... as always! :D
I'll change my sig to "The lonely Stag" :)
Altho it did get some attention :(
Edited by RubyRS4
Just got home from meeting up with the cruise after I finished work (11:30).
Good to meet some new people, and have a bit of a strap through the hills in the process.
There were only a few left on the cruise by the time I met up with them since apparently people can't read cruise sheets. My excuse for leading people astray was that I didn't have a cruise sheet :)
Anyhow Cheers to all involved;
Oh and by the way happy birthday Kahli :banana:
think some people accidently followed me when i was just heading home :banana: i turned down a random side street after i relized so they got the idea this wasnt the cruise
i just rolled up for the initial meet n greet n decided ive spent enough $ on petrol this week, not a bad turnout seen it was mainly skylines that showed as aposed to random v8s
Edited by Inline 6
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
