I've never had a plasma with damage from "screen burn" in the 5 years i've been
working in the industry.
Samsung, LG, Pioneer and Panasonic all make Full HD 1920x1080P panels.
A famous footballer (Magarey medalist) here in SA and good mate of mine had real bad image burn from a Pioneer Plasma after 11 months.
Radio Rentals replaced it with an LCD.....he paid the difference.
Just a question about the above brands......so don't give me another smart arse answer or I'll jump thru ya monitor and tear ya head off......are all those brands with that resolution actually plasma?
I'm definitely no expert in this field but 5 years doesn't make you a rocket scientist either.....my brother has been doing it for 17 years and my brother in law since the late 70's so I'll need to clarify info with them.
  • Replies 102
we have the non true HD 40' Bravia and have to agree even though its only 1366 x 768 it looks awsome only thing that lets it down is the broadcast on foxtel
yeah true, not for long though.....apparently they're getting their act together with a select few channels
Plasma = 1366 x 768 Max
LCD = 1920 x 1080
How can plama quote true 1080i HD then?
Was never an issue with SD but just because you can send a HD signal thru a Plasma, doesn't mean you get true HD......only possible with LCD!
Huh? :P
The high end Panasonic, Samsung, LG plasma panels are all 1920x1080 res.
My parents got a 50" Panasonic Plasma thats true 1080p,although we don't have anything that high to use it on yet... :banana: , all they watch is SAT TV & pirated chinese DVDs that encoded in vcd res (320*240) which looks horrible on it... :banana: , my Wii is the only thing that puts the TV to decent use, unit I get a PS3.
Maayyyte, I know that..........I'm saying that to get the full advantage of the blue ray disc, you need LCD
Please explain in more detail here, for a 1080p LCD vs 1080p Plasma, they both have a native 1920x1080 res so a Blue Ray disc would display in full detail on either one.
In general, LCD tends to have shaper pictures while Plasma's tend to have more smoother fast motion picture.
As for the burn in problem on Plasma panels, its not that common anymore (it was a major problem for the 1st couple of generations of Plasma panels), although still be a luck of the draw I guess. A friend have got this really generic cheap chinese made SD plasma panel (852*480 res) & all he watch on it is SAT TV where the chinese channels all have a still logo on screen, & he has being using that TV for 2years now & no burn in yet.
yeah fair call....I didn't think the plasmas could get the same res as the LCD's but I stand corrected.
I just got a bit fired up over that clown's smart attitude from the eastside.....very easy to do when you're 1600km away
i still believe that MOST LCD panels are better than plasma due to dot pitch too
alot of LCD TV's have smaller pixles than Plasma
also it doesn't seem so common now a days but the first few generations of plasma you could see black lines between the pixels if you sat too close
Hahaha i created a monster, thanx for all the inputs guys. Im 90% sure the branded tv is what im going for, so saving abit more dosh is in order. Then theres this... :D
http://www.kogan.com.au/shop/kogan-1080p-4...cd-tv-hd-tuner/
Click on specifications for full goodness.
Hahahaah this is great!!! monster indeed!
Ok. I have sony bravia too guys... only HD 1366x768 not full HD 1920x1080.
Plasma is available in full HD and was first released by panasonic in Aus. around september last year.
Whether to go HD or full HD will depend on what type of viewing yo do... it all comes down to SCALING.
for example a dvd uses approx 720 line images. If your tv has 768 resolution then its a virtual direct display (no scaling involved) however if you feed in a full HD image it must downscale from 1080 to fit 768. This will still give a good quality picture.
Going the other way with a standard picture (approx 576 line image) and feeding it to a screen with 1080 resolution involves a large amount of scaling to make the image fit and will show just how poor standard tv and foxtel broadcasts are. ie look pretty crap.
So, if you watch mostly foxtel and the occasional dvd go for a HD 1366x768 panel.
If you play ps3 and want to be blu ray and future proof go for 1920x1080 as this is where all development is currently heading.
Doobs... what u smokin???
Lg do not make most lcd and plasma panels. How do you explain the fact that plasma was developed by four brands... mostly FUJITSU,HITACHI, PANASONIC and NEC. Fujitsu were at one point supplying panels to 70% of the market. True that sony did not make their own plasma... it was a hitachi panel.
Sony do make their own LCD tvs. They have a joint venture with samsung in korea to produce native lcd panels, then they are shipped to sonys facilities in japan for X and XBR series, or malaysia for other series where sony add their electronics etc.
Further to this approx four months ago pioneer announced they could no longer compete in plasma only markets and are now purchasing SHARP lcd panels (from sharps kameyama plant in Japan) and rebadging them pioneer. They are now also buying plasma panels from panasonic and rebadging them.
Sony are also looking at this possibility with regard to the japanese lcd panels from sharp.
With regard to image burn on plasma... yes it is possible but highly unlikely with any late generation panels.. earlier ones not so good. I have personally left a static image on a pansonic plasma in our shop for 9 hours straight which resulted in slight image retention or ghost image. After running said panel for another couple of hours on normal tv this has gone. However if you are a big gaming fan I suggest LCD.
sorry for long post guys... could probably keep going!! cheers Martin.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
