between 150 and 153 off the top of my head, and the engine builder said the #5 cylinder was one of the higher readings.
I cant think of any reason could it be weak spark? think i will check the connection on the ECU
https://www.sau.com.au/forums/topic/224292-miss-at-idle/#findComment-3951016
Yep fuel pressure seems ok have a fuel pressure gauge on the car and it seems to work fine have 40 psi at idle and 58 psi at 1.1 bar boost and AFR is 11.4 at WOT. also have wide band.
I checked spark by removing coils, earthing them and installing another set of plugs into the coils and turn the engine over. So it has spark of some sort. Have another set of coils off and old engine i brought and it seems to make no difference.
Sprayed heaps of brake cleaner on the intake side looking for a vacum leak but after a half a can it didnt make any difference at all.
very strange.
https://www.sau.com.au/forums/topic/224292-miss-at-idle/#findComment-3951472
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
