hi ya all
not sure if this is the right spot but any ways
i think its about time to change my fuel pump soon and was wondering is there any difference between the series 1 R33 fuel pump and the S15 fuel pump? is it worth change it over ?
reason i ask is because i got one lying here so if it can be done i dont have to buy one
cheers
https://www.sau.com.au/forums/topic/224298-fuel-pump/
I think you will find the s15 one wont flow any more than the stock r33 one, and if it did i could not seing it be much more.
tomei,nismo and hks pump for direct fit are around $370 to ur door, and flow at 250lph and
are direct fit.
Or look at the bosch or walbro direction even gtrpump is pretty good,but youneed to make it fit the cradle
and is not to difficult.
Cheers :thumbsup:
https://www.sau.com.au/forums/topic/224298-fuel-pump/#findComment-3951138
Yeah im sure the s15 wouldnt flow much better than a 33 just think about how much bigger the engine capacity is compared to a 2litre 500cc is a big difference also the rb25 has more power from the factory i dont think the japs r stuppid enough to put a smaller fuel pump in a larger capacity motor well it's my opinon anyway! If you want your car to have a fair bit of power with out the headache just get a tomei or nismo!
https://www.sau.com.au/forums/topic/224298-fuel-pump/#findComment-3958950
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
