  • 3 months later...
  Lozza150 said:
This Link has details of how to bypass HICAS for racing.
http://homepages.tig.com.au/~robs/hicaslock.htm
A very interesting link but it prompts some questions:
Does all of the above apply to R33 GTS-T's, which have a different version of the HICAS to that of the R32's?
If the kit is suitable for R33's, where can it be sourced?
As I run my R33 in supersprints I have at this stage just pulled the fuse on the HICAS system to de-activate it. I did this after installing a full Whiteline suspension kit and it seems to have eliminated most of the feedback I was getting through the steering wheel on fast sweepers - but not all of it. My next move was going to be to take the rack off and simply fit a rigid but adjustable bar in its place. Any thoughts on this?
  • 5 months later...
Paul
Its quite safe to remove the rack(and save about 20kgs in weight) and replace it with billet aluminium plate or fixed tube with threaded ends which you can attach adj rose jointed arms with which you can adj your toe in/out.I have been running full whiteline kit with bilstein coil overs and no hicas for two years now with no side effects,a better handling car and much better tyre life!!!
Regards,
SKYLINE...(Kym).
Paul
Regards,
SKYLINE...(Kym).
  skyline said:
Paul
    Regards,
                   SKYLINE...(Kym).
Thanks for your reply, Kym. That's just what I envisaged could be done but so far I haven't really tried to find someone to make it up. I did talk to the suspension guy who installed the Whiteline kit but he thought it was all a bit hard and a race preparation specialist I spoke to looked at it and seemed to think that it wouldn't really be any more effective than switching off the rack and leaving it on the car - but the weight saving is attractive. Do you think your fabricated bar works better than the switched-off rack?
Paul.
BigDatto, thanks for the plug.
I found I noticed the rear subframe moving around a bit on track after the lock bar went in so I need pineapples of alloy lock spacers. The fitting is easy but you need a wheel alignment after (just to whiteline specs for toe) and the light will come on but you could pull the dash and remove the globe.
  • 3 weeks later...
i fitted one of geoff's lock bars (i recommend it) but now my steering is heavy at low speeds - any ideas why?
previously i had the tomei hicas lock kit. this included a computer unit that u wired into the hicas computer, but i removed this and this is when the problems started.... so everyone else with the lock bar has perfect steering?
  • 1 month later...
possibly try reconnecting the wires that you spliced for the tomei kit.
when i bought my car, the whole computer at the back had been disconeccted and after i connected it back up the steering was back to normal, as it had been also very heavy as u mentioned. so i suggest trying just connecting the wires back up if u havn't already
  • 1 month later...
Lozza150,
Couldn't re-find the post you started on HICAS Diagnostics so I was just wondering if you could answer the folloing question. I ran the diagnostic check as you stated to do on an R33 GTS ( non-turbo ) and got the following results:
- 10 fast flashes
- 5 second gap
- 2 long flashes
- 2 short flashes
Any idea what that indicates as faulty ?
Thanks in advance.
  • 1 month later...
Ok, Ive also stumbled across a trouble with the hicas but it happened when i installed a ebc - profec a to be exact. Can any shed some light onto why this is happening. I only noticed that the hicas light was on once i installed the ebc and was going to take it for a few runs. The light doesnt seem to go away anymore.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
