  • 3 months later...
This Link has details of how to bypass HICAS for racing.
http://homepages.tig.com.au/~robs/hicaslock.htm
A very interesting link but it prompts some questions:
Does all of the above apply to R33 GTS-T's, which have a different version of the HICAS to that of the R32's?
If the kit is suitable for R33's, where can it be sourced?
As I run my R33 in supersprints I have at this stage just pulled the fuse on the HICAS system to de-activate it. I did this after installing a full Whiteline suspension kit and it seems to have eliminated most of the feedback I was getting through the steering wheel on fast sweepers - but not all of it. My next move was going to be to take the rack off and simply fit a rigid but adjustable bar in its place. Any thoughts on this?
  • 5 months later...
Paul
Its quite safe to remove the rack(and save about 20kgs in weight) and replace it with billet aluminium plate or fixed tube with threaded ends which you can attach adj rose jointed arms with which you can adj your toe in/out.I have been running full whiteline kit with bilstein coil overs and no hicas for two years now with no side effects,a better handling car and much better tyre life!!!
Regards,
SKYLINE...(Kym).
Paul
Regards,
SKYLINE...(Kym).
Paul
    Regards,
                   SKYLINE...(Kym).
Thanks for your reply, Kym. That's just what I envisaged could be done but so far I haven't really tried to find someone to make it up. I did talk to the suspension guy who installed the Whiteline kit but he thought it was all a bit hard and a race preparation specialist I spoke to looked at it and seemed to think that it wouldn't really be any more effective than switching off the rack and leaving it on the car - but the weight saving is attractive. Do you think your fabricated bar works better than the switched-off rack?
Paul.
BigDatto, thanks for the plug.
I found I noticed the rear subframe moving around a bit on track after the lock bar went in so I need pineapples of alloy lock spacers. The fitting is easy but you need a wheel alignment after (just to whiteline specs for toe) and the light will come on but you could pull the dash and remove the globe.
  • 3 weeks later...
i fitted one of geoff's lock bars (i recommend it) but now my steering is heavy at low speeds - any ideas why?
previously i had the tomei hicas lock kit. this included a computer unit that u wired into the hicas computer, but i removed this and this is when the problems started.... so everyone else with the lock bar has perfect steering?
  • 1 month later...
possibly try reconnecting the wires that you spliced for the tomei kit.
when i bought my car, the whole computer at the back had been disconeccted and after i connected it back up the steering was back to normal, as it had been also very heavy as u mentioned. so i suggest trying just connecting the wires back up if u havn't already
  • 1 month later...
Lozza150,
Couldn't re-find the post you started on HICAS Diagnostics so I was just wondering if you could answer the folloing question. I ran the diagnostic check as you stated to do on an R33 GTS ( non-turbo ) and got the following results:
- 10 fast flashes
- 5 second gap
- 2 long flashes
- 2 short flashes
Any idea what that indicates as faulty ?
Thanks in advance.
  • 1 month later...
Ok, Ive also stumbled across a trouble with the hicas but it happened when i installed a ebc - profec a to be exact. Can any shed some light onto why this is happening. I only noticed that the hicas light was on once i installed the ebc and was going to take it for a few runs. The light doesnt seem to go away anymore.
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
