hey guys im new to the forums, ive got a 96 33 gtst some simple mods fmic 3'tbe mbc running about 10 psi.
recently i have been getting a problem while the car is under full load. boost will wind up to about 10psi and the car will hesitate and almost cut out the a moment later kicks back in at full boost. almost like fuel is being delivered at incorrect pressure or not in time.
am i right to say this would be a fuel/pressure related problem rather than a boost cut or computer issue?
would it be as simple as a new fuel pump and fpr
any ideas would be really appreciated
thanks guts
ben.
could be rich and retard - do a search for that and R&R to see if descriptions match yours.
could be fuel pressure related as well, only way to check is with a guage setup and take it for a drive, all std mechanics should be able to run a check on that while you drive the car.
thanks guts
ben.
wow....same car and problem here......my car is at TGS Performance as we speak, getting a new Denso Fuel Pump. (<>$450 fitted)
I'll let you know how I go.
Cheers.
Cheers.
see thats what direction i was heading in, the way fuel is delivered (or lack of) points towards fule pressure issue possibly from pump malfunction or failure. another idea was to check lines to see if blocked and also install fpr. i picked up a turbosmart fpr and am going to get a walbro item which are necessary modifications anyway and see if there is a difference.
ive just been converted from owing a subaru rs liberty so am fairly new to the rb25. if ecu was going into r&r mode then would it throw a code?
im pretty sure the r33 dosnt have r&r mode which only happen if u touch the standard boost solenoid wiring but these days u c so many skylines getting around with it disconected and then running high boost!
the r33's certainly do have R&R and it feels nasty when it cuts in.
it is air flow based not boost reading.
so if it is r&r mode then how do i go about diagnosis/ fixing?
ok so car is now running wastegate pressure and problem is still occuring. thinking of just sourcing pfc (which is logical mod anyway) and seeing if it rectifies problem. anyone know any good pfc tuner in western sydney (im in castle hill)
Hi, just an update after getting the car back (as above).
It was a heavy duty Bosch (in-tank) pump they installed (don't know why I said Denso earlier)...car now picks up smoother and more linearly (not in stages as it use to)....but still hits the 'sudden stop' syndrome when using higher gears and pedal to the metal......(Jolts badly).
When in a low gear (1st 2nd) no probs...very quick.
I have just gone out and taken the bleeder valve off my car (back to stock now..around a boring 7psi, not 11-12)....will test drive and see what happens.
Looking forward to seing if the 'black soot' returns to my rear bumper bar.....like it use to!...
But I do recall a little while back that a split was found in my IC piping, that was fixed and all was great....might have to get it all checked out again, I don't have the back for it right now.....hopefully the CT scan on my lower back I had this morning will finally find the answer!....to that problem anyway.
Anyways...I'll come back after a drive, if I can, shortly.
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
