yeah steve. I told u b4 its Chris Miltons. You got a qoute from them by memory, but it was too much? Interesting though - I have heard (on good authority) that the same work I'm getting done would've costed anywhere up to $1100 from another engine developers. Chris is pretty cheap - but it does save u to take the head off yourself :D
  • Replies 49
Hi All,
Head portings going well if slowly :)
I've been told that you should use an 80 grit sander for the final finish on the inlet port to promote fuel/air mixing but it looks a bit rough to me. Does anyone know if thats the correct finish for aluminium ? ;)
I remember a while back i wanted to do this to my car. Basically i found out alot of good info on techniques and such. What i would personally do is go to some place which has old engine heads for scrap, and use it to practice the correct techniques. That way when it come to ur real head, u shouldnt have too much trouble.
Also A dremel i find is the perfect tool for this.
Funny you guys are on the subject cuz Im in the process of redoing my rb26 head. Im going through the head and porting and cleaning up the combustion chamber for better burn. Now, for the humps on the exhaust side, my theory on those is smooth them out as much as you can. If you were to run into a stud the worst that could happen is that you would have a very small exhaust leak through the stud itself (very unlikely). But it will pay nicely with power increased and better spool up too.
Chris milton ported and polished up both the inlet and exhaust ports. He said some thing about concentrating on the bowl area.
He also cleaned up the combustion chamber so that the air was able to flow in to the cyclinder a little easier hence removed material and then polished that up also. On the Inlet valves he did a 3 angle valve job I think it was and on the exhaust he did a different valve job which made everything really round. I'll find out the exact terminology.
It ended up costing a little more than anticipated as he forgot to mention that its extra to shim the valves when setting up the hydraulics, not sure exactly but u get the idea.
Finished the head now and pictures will follow shortly.
The porting was all done using a cheap air powered die grinder and a Standard Abrasives porting kit. Took me 3 days to do it but I reckon I could do one in 1.5 days now I know the areas to concentrate on. Hope this information is useful to everybody :)
Originally posted by -Joel-
damn.. My camera won't take pics that clear..
What camera are u using?
Its a Fuji S602 camera I think, its not mine its a mates.
I just edited the thread with a load of pictures and a description of what I did but its been rejected :) .......I'll do them as seperate posts.
The original exhaust port showing the intrusive port bumps
The finished exhaust ports....
From the combustion chamber side....
All of the intrusive exhaust port bumps were removed the ports were enlarged to the exhaust manifold gasket.
All casting marks were removed.
The divider was knife edged and the valve seat area was blended into the bowl.
The 'short' side of the port was radiused as there is a fairly sharp edge where the port turns into the bowl area.
The exhaust ports were finished with a finely polished shiney surface to slow carbon build up.
Standard inlet port....
Finished inlet ports....
The inlet ports are very well shaped in standard form and have 3 angle seats as standard.
Inlet ports were all enlarged to the inlet gasket.
The area where the valve seat meets the bowl was blended smoothly and all port casting marks were removed.
The divider was knife edged and the ports were finished using an 80 grit sanding roll to promote good fuel/air mixing.
Combustion chambers......
All combustion chambers were smoothed and polished thoroughly to reduce the likelihood of detonation and also to slow carbon buildup.
The combustion chamber shape has not been changed at all so compression ratio should be unnaffected.
  • 1 month later...
If you didnt have to buy a new head gasket when you remove the head i would grind and polish it all up myself... bit of a pain .. maybe one day when i need to rip the head ill do it ...
I got a question, ive got my exhaust manifold off at the moment and i was wondering if its a good idea to grind and smooth the inside of the manifold since its off anyways?
Another question i got is on the manifolds turbo outlet there is a divider in the middle that seperates the pipes - OOO|OOO -
anyone know if i can play around with that ? eg. like make it a knife edge or totaly remove it ... It has a slot in the middle of the divider as well ...
oh and make sure you don't go to thin as it will crack. Get a pinch measuring tool to check wall thickness. don't go under 2.5mm.
Also some of the bumps near the outlet are purposeful to direct the airflow around a the bend, these need to be smoothed rather than removed.
Be carefull knife-edging the outlet as a heat fatigued piece of broken metal will kill your turbo in a second.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
