Do R32 GTST's have a boost fuel cut? My car did it twice this morning but it wont do it any more, I got to servo and found the positive termal wire was loose and i had to move it to get my car to start.
na i odnt think so im running 12 psi on my car with just boltons and never had it cut out
https://www.sau.com.au/forums/topic/224430-rb20-fuel-cut/#findComment-3961488
RB20 ecu's have a mass airflow sensing cut that cuts injector pulse as soon as the AFM reads a given voltage depending on the air flow/rpm range.
typically even with an RB25 turbo it will not hit this unless it is a really cold day. You can have the ecu remapped to fix this and also customise your fuel and timing maps to suit your needs.
https://www.sau.com.au/forums/topic/224430-rb20-fuel-cut/#findComment-3961670
Mine used to hit it running around 15-16psi on the standard r32 turbo on an icy night or morning. :S
Generally up at around 5000rpm.
I then bolted the rb30det in with the stock ecu and it would hit the fuel cut around 6psi at ~3500rpm with the stock rb20det turbo.
https://www.sau.com.au/forums/topic/224430-rb20-fuel-cut/#findComment-3961893
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
