Hi guys took my s15 in for a tune @ EFI Performance on the gold coast pretty happy with results but as Im no expert in tuning I want to know if the charts look good and if the AFR's are where there ment to be....cheers
Mods:
XTR GT3040 (.70 Comp, .64 Exh)
42mm External Wastegate with Screamer Pipe
HKS Step 1 Camshafts (256in, 264ex – 11.5mm lift)
HKS Adjustable Cam Gear
HKS 740cc Injectors
HKS EVC IV Electronic Boost Controller
BLITZ BOV
Malpassi FPR
5 Speed Manual Gearbox from S14A
Exedy Clutch
Tomei 250lph fuel pump
Top Mounted Exhaust Manifold
K&N 4inch Inlet Pod Filter
Hybrid Deltafin Tube & Fin Intercooler Kit
Trust Power Extreme 3" Stainless Steel Exhaust
Xforce 3inch High Flow Cat
Wolf3D v4 Plug-In Programmable AEM ECU
before tune: 208.6kw @ 10.9psi
after tune: 274.1kw @ 17.8psi
Cheers
https://www.sau.com.au/forums/topic/224441-dyno-results/
  • Replies 54
it's okaaaay. except for the fuel control as it's ramping up onto boost. as it ramps up to near full boost the fuel is not keeping up and it hits the 14:1 AFR as boost ramps up to 16psi before dipping down to ~12.5:1 which is ok. but the boost ramping area is always tricky and is usually where you get detonation. as the power and boost pressure start to rapidly increase the tune needs to be adjusting fuel and timing in a hurry to cope. if it were me I would probably want that little area of the tune looked at a bit further.
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3952680
Ok
1. AFR's are dreadful around 4000-4700rpm. They should not be around 14's as its ramping up
2. Boost controll is average, i mean you only have 160rwkw @ 4500rpm.
5000rpm you've only just hit 230rwkw and there is a nasty hole right there until it lifts up again towards 260
For a turbo of that size and that rear housing, i would expect it to be noteably better
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3952828
thanks for the info guys, appreciate it...just spoke to the tuner then will be taking it back 2moro to get more fuel added around the 4000-4700rpm. he did mentioned after the run that you see in the graph he added more fuel down low and a bit more up top but didnt do another power run. Ill get him to sus out the dip in the power curve up top aswell. R31nismoid you mention the boot controll is average and its only got 160kw @ 4500rmp then just hits 230kw at 5000rpm......becuase of the size of the turbo it is pretty laggy and when im in the car and plant it rght up to almost 5000rpm u can feel the car isnt really under much load its trying to spool and boost up and soon as it hits around 5000rpm it almost instantly then hits 7000rpm really kicks in hard...is this cause of the tune or cause of the lag? cheers
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3952876
ok i added a new AFR line on how it should look like, or there abouts, it could get richer about 500rpm earlier but you get the idea.
Tune em rich, enjoy your engine for a large number of years, tune em lean ??? then your keen!
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3952945
thanks guilt-toy I really appreciate it...thats wot I said to the tuner when i 1st took it in, I said I would rather less power and a realiable tune then running it as lean as possible to get as much out of it as u can...will definatly not be goin back there again in the future and wot makes it worse it cost me $1000
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3953014
Mate go back to him, give him another chance, tell him to fix it properly and get a reliable tune!
He might have been having a bad day / week.... surely he will fix it for free. $1000 man, far out i feel bad for you... but for that kinda money you would EXPECT backup support.
Go back to him and tell him you want the AFR to be 12.4 from 2 - 8psi and then from 8psi to 12psi you want 12.0 and from 12psi to 18psi you want 11.5afr to 11.8.
If he does that for you then he may be a good tuner to use in the future.
good luck with it!
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3953045
yeah, mine was leaning out on monday on the dyno, had to go from 770cc to 1000cc sards...now i need a fuel tanker to follow me around. but oh well i shouldnt complain.
that has like no power till 3700..that would be good around town driving car.
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3953051
i hope you have more then 700hp at the rear wheels?
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3953104
If your on the coast why didnt you take it too matty spry?
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3953165
hmmm maybe you should worry.. you don't need to know shit or have any tickets or anything to have a tuning shop and a dyno.
Maybe you should ask for your money back. drive down to nsw, get it tuned and drive back and you will have change from your $1000 lol
Try mercury motorsport?? i dunno i don't know any places up there mate. good luck with it though.
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3953349
I'd say combination of both potentially.
Boost control needs setting up better, as does the tune require a fair bit of work.
Also it could be cam timing is off causing this too... a number of things for the tuner to think about thats for sure
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3953428
boosted 32.
Was yourse the orange S15?
If so my missus wants it, lol. thing is niiice.
Mate you would have seen my VL there, white/silver VLT calais, GMH.088.
As for the tune. no doubt they will do it again if your not happy, i don't understand all that tuning stuff but ive spent over 18grand on my engine, and i wouldnt have taken my car there if i did'nt trust the boys @ EFI.
There history specks for itself...
Edited by CLNGMH
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3953808
boosted 32.
yeh u got it...thats my s15 EFI seem to know wot there talking about and doing but after loading up the dyno charts on here every single person is saying its running to lean, not one person has said its half desent....this worries me I will be taking my car back there 2moro to hopefully sort all this out, cheers
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3954562
dopped my car off at the tuners this morning had a chat with him and was told he did add a bit more fuel down low and up top before he finished but didnt do another power run , so the graph I got was wot it looked like before he adjusted it. His guna put it back on the dyno 2day and make some adjustments aswell so I will upload the graph at the end of the day and see how we go.....I appreciate everyones input, cheers
https://www.sau.com.au/forums/topic/224441-dyno-results/#findComment-3955253
    • PRICE  : $1400 LOCATION   : NSW Central Coast FIT  :  All Nissan 350Z type Z33 and Infinity G35 Coupe. See delivery note. Hi, brand new, unused, still in the box.  ($1850.00 is what i paid ) My bad luck !!! I thought my right front  Bilstein was cactus so i bought the ST 's to replace all.  Turns out the right front is fine ( loose mounting after service  by a well known importer of Bilsteins ) So im selling the ST's. They are made by KW ( no intro needed ) . Iam on the Central Coast and im willing to meet up in Sydney metro, within reason and Newcastle.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
