What were you trying to find out exactly? (specs or details of the car, build date, accident history, finance owing, etc?) ... some of these things are not possible to find out in the same way as they do in the US, others are quite easy if you have the correct details and/or know how to check?
Unfortunately there is no central register of accident repairs or servicing in Japan, so for this sort of information you just have to trust the seller. Obviously some cars will come with service books so that's a good start but make sure you trust the seller as some dodgy exporters will buy blank service books and fill them out then wind back the mileage to appear genuine. As a general rule the Japanese are quite honest and a normal Japanese individual seller will tell you honestly about any accident repairs in most cases, the auction houses will be as honest as possible although sometimes mistakes are made, and it's normally the non-Japanese agents who go there to purchase and export cars who are the ones that do dodgy things and misrepresent cars.
With all of that said, just buy from a good trusted source and get heaps of additional information and/or photos until you are happy with the condition of the car - don't let anyone pressure you into buying before you are comfortable and ask any questions that you have so all of your doubts are answered and you should be good.
If there is a specific car that you are looking at then I might be able to check the information and do a quick history search for you if that would help? .. feel free to private message if you prefer not to make the details public.
  • 1 month later...
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
