http://www.prestigemotorsport.com.au/modul...hp?StockID=4647
btw.. Interesting what they say:
PLEASE DO NOT ASK ABOUT IMPORT FOR ROAD USE AS THIS MODEL WON'T BE ELIGIBLE TO BE ADDED TO THE SEVS LIST AS A SECOND HAND VEHICLE UNTIL 18 MONTHS AFTER FIRST RELEASE IN JAPAN (ie. APPROX. JUNE 2009), PROVIDING NISSAN DOES NOT IMPORT TO AUST. IN FULL VOLUME BEFORE THEN
So the R35s getting quietly listed cannot be complied until mid next year? if nissan are slow?
https://www.sau.com.au/forums/topic/224476-an-r35-for-less-than-80k-aud-landed/
but what don't get is the hints that there are R35s that can be for road use available or
soon to be available for nutty prices (160k), and there is one compliance shop so far that
has done the work to comply them.
But this advert says flatly that nothing can be done until 18 months after the japan
launch date. And if nissan import before mid next year nothing can be done at all, leaving
anyone buying one hoping to get a blue slip, in the lurch.
how to reconcile those two things?
That car has also been rear-ended... It's cheap, but personally if I had that sorta money I'd prefer to hunt down a straight one over a cheaper, crashed one.
We'll get the jap spec ones before aussie nissan gets them here I reckon.
I think Prestige Motor Sport are just playing it safe, cause they know its a pretty thick Red Tape ATM with all the SEVS and what-not.
So if you can get a cheap one like this, repair it and get it to Road use then thats friggin sweet!
I would like to go for the V-Spec Model.
correct me if i'm wrong , but if you import a car for rally/race purposes it would never be able to be complied for road use. I though that to register a car it needs to be imported as a road car to begin with. If i'm wrong then this would be a bargain to buy .
regards
mike
The guys selling the GTRS for 160k are not selling them as second hand I believe but rather as limited numbers of brand newies. I dont think SEVS allows you to bring in damaged cars for road use anyway or even cars that have had accidents and repaired.
Hahaha wouldn't buying a rear ended R35 just be a great idea...
That'll be an easy fix, just head straight on up to your local Nissan dealer and grab a few new R35 panels that they obviously dont have...
I have heard...so its just a rumour...that if you ask nissan for parts for your R35 (panels) outside Japan - they have the right to refuse supply.
Although I guess it wouldnt stop you using a supplier in Japan who would then whack on their %.
Cheap 35 though! nothing that gaffer tape couldnt fix!
  • 1 month later...
Needs at new quarter, bever panel, rear bar, tail light and a skilled workshop to do it. You may get change out of 20k to fix it properly if you can get the parts.
Any idea how much cheaper the import ones will be compared to the local ones? I can't afford the circa 150K price. lol
  • 1 month later...
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
