I can make boost in neutral from idle but that a pissant 25 turbo on a 3L, 5psi or so if I rev it up.
How's this though.. I can get some flutter or pssht while still in vacuum which is reasonably normal BUT, when I first put the motor in and didn't have the bov tight enough (so it wouldn't leak at idle), it was BLOWING air OUT at idle, not sucking in as you would assume while under vacuum.
I put that down to the turbo spooling from idle so even though it's not creating positive pressure yet it's still pushing air in as opposed to the engine just drawing in what it needs at idle.
Or am I way off?
good ole cb70's... man you can chuck some timing into those! forgies standard!!
NAH, you have to go real old school on those, G11 with a cb60 (i think that was the one, or was that the atmo) carbie turbo FTW, got some pics around somewhere of me doing roll backs in my old G11 atmo, man that thing took some punishment.
on topic, mine does not build any pressure standing still, but i also have a .8 rear so that would not help.
    • Not alot of room in the front or mid pipe to play with Helmholtz chambers, plus they are pretty hit and miss getting the length and volume right, and time is money when it comes to trial and error testing at a exhaust shop, it isn't like test fitting mufflers or resonators From previous experience with exhausts and trying to tone down the volume and eliminate some drone, a resonator in the mid pipe typically make it much better,  and even possibly stop Jackie complaining about it, me, I really don't notice it that much, but, I am pretty deaf 馃ぃ
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30掳bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • www.rollracing.com.au tickets aren鈥檛 live yet
