Nsw: Hr31 Coupe 4 Sale *must Sell*
Guest autoas
 Share
Guest autoas
MakE: NISSAN
Model: SKYLINE HR31
Milage: 200000
Transmission: 5-SPEED MANUAL
Colour: WHITE
Complied? YES
RWC supplied? YES
Currently registered? YES
Price: $9000
Contact: 0419538999
Comments / Modifications: HIGHLY MODIFIED PLEASE ENQUIRE
Images:PICS AVAILABLE
Guest autoas
Hey, got a url for pics?
got to http"//www.carsearch.net au/cars/seller/index.php?pag=car_view&car_id=4919
Guest autoas
MakE: NISSAN
Model: SKYLINE HR31
Milage: 200000
Colour: WHITE
Complied? YES
RWC supplied? YES
Price: $9000
Contact: 0419538999
price drop to $8200
MUST SELL!!
Guest autoas
How long is it registered for?? If your still keen to sell iv got $4500 cash.. let me know...
how bout you at least look at the car before you low-ball me champ!
Guest autoas
It doesnt say ANYTHING about how long its registered for there... What am i supposed to do, noone had even looked at the thread for 2 weeks until i posted, if you dont like the offer you can just say no, and not be a d!ck about it.. champ
m8 not that rego has got much to do with the price i am asking, but it can be rego'd with 12mnths for that price i am open to negotiation. $4500 grand is pretty close to what an autronic sm2 and cdi retail for (not that you get back what you spend on cars!) if you r genuinely interested the car is still for sale but you need to be a bit more realistic.
  • 3 weeks later...
Guest autoas
MakE: NISSAN
Model: SKYLINE HR31
Milage: 200000
Colour: WHITE
Complied? YES
RWC supplied? YES
Price: $9000
Contact: 0419538999
PRICE DROP TO $8000 NEGOTIABLE. CAR IS NOW OUT OF REGO - WILL RE-REGO IF BUYER REQUIRES OTHERWISE NEGOTIABLE WITHOUT. NEED THIS GONE TO FUND OTHER INTERESTS!!!!!
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
