Item: Tomei 2 Way Diff
Age: 2000kms
Condition: As new
Price: $1,100ono
To Fit: (What car) R33 GTST & GTS
Contact: [email protected] or PM
Comments: Selling a complete diff fitted with a Tomei 2 way centre which is almost brand new. This has been fitted to a diff that has a 4:3 ratio. Was purchased recently for our car but doesn't fit as we are running a GTR rear end and the driveshafts are different. Selling for less than the replacement price of the centre alone. Also comes with the Tomei gear oil. Can arrange fitting for a small additional charge.
Item: Exedy triple plate clutch
Age: 3500klms
Condition: As new
Price: $1,900ono supply only, $2300 installed
To Fit: (What car) all RB series engines
Comments: Exedy triple plate clutch to suit RB series engines. It is the heavy duty version which has a heavier pressure plate. This clutch is only 3500klms old and was only used to run the engine in and for the tune up after the run in was complete. As such the clutch is in as new condition and is out of the car ready for sale. I can do this clutch supply only or installed for a small fee. Supply only price $1900, installed $2300. Reason for sale, gone OS Giken
Brad
Edited by ido09s
https://www.sau.com.au/forums/topic/224528-tomei-2-way-diff-exedy-triple-plate/
    • Ok awesome! I’m not running a aac/iacv (although I do have the r34 iacv but I’m running the heater core loop. I’m running the chase bays booster delete so In that case would I need to block off those posts? So at the moment I need to run from one of the posts to the fpr and then a separate post to the boost controller then to the wastegate? Also I’m assuming that each port has a specific use like the first one farthest to the left would be (for example) manifold to fpr and then second would be to boost controller?
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
