Hi all,
Car: R34 Series 2
Alarm: Autowatch 446Rli
Battery: Marshall battery (less than a mth old)
About a mth ago my car battery died for no reason. Battery was from Japan (i imported the car) hence i didn't complain much. Bear in mind i'm a weekend driver and i usually start my car every 3-4 days.
After changing to a Marshall battery, all is well until an hour ago when i tried to start the car like i usually do, the battery is now dead AGAIN !!! It's a brand new battery which is less than a month. When i tried to start the car i noticed the battery meter is howering at 10 at the battery gauge. After a few tries, it's currently sitting at 8. The interior lights are working but not my hid / parkers.
Ok, here's the thing, when i insert the key into the ignition i keep hearing this sound every 5-10 seconds from my alarm's hub (tick, tick, tick). Is there anything wrong with the alarm? Is the alarm draining the battery ? Is it a grounding issue ? Is my ecu fked?? What i can say is the battery will most likely be alive again after a jump start but i'm afraid this might occur again in the future.
Any recommendations as to where i can get my car's alarm to be looked at, at WA ?
Please advise guys
Edited by hotchoc
https://www.sau.com.au/forums/topic/224543-r34-alarm-battery/
I'd say the ticking is because your battery is flat, some relays dont have enough voltage to close.
Sounds like you have got a problem somewhere if your new battery is going flat, first thing to check would be alternator charging voltage. Next thing to check would be standby current, using a multimeter which would confirm if something is draining it.
Hey mate,
I'm calling the road side assistance guy from Marshall. What should i tell him to check for?
1. Alternator charging voltage? - What's the normal range ?
2. Standby current - what should the person be looking for?
Do you have any idea wat's draining the battery power? My frd said it might be the wiring of my alarm (i.e. incorrect grounding etc)
idle current with car off all closed no lights on 0.05A. if more then something is wrong. battery charge voltage is 13.5-13.8v if 12.60 or less alt is dead and more than likely has a shorted diode. either way it has to come off.
Using the multimeter, everything shows it's normal
14.67v - no light on except the engine
14.61v - high beam on with engine
Draining of power = 0.08 to 0.09 when car is off
According to the chap, my alarm (immobilizer and alarm keypad) is draining my power as i hardly drive it. I drive primarily on weekends and he said this should be ok provided i drive the 34 on a daily or alternate days basis or it'll prob drain out in 4-5 days time.
I also fd out my battery is the Marshall 40D battery with only 300CCA cranking power. Is this power sufficient for 34 owners?
The guy reckon it's better for me to go for the XD60 with 380 CCA which would be sufficient for the way i drive (weekend driver) and also cos i'm planning to get amps, speakers, woofer, etc but in order to do this, i need to swap my terminals to the larger ones to accommodate this type of battery. Is this advisable ?
Btw, there's nothing wrong with the alarm / wiring, alternators, etc.
What do you guys reckon?
This test is flawed, it only really shows what the alternator is putting out, and has little to do with the health of the battery.
However if it holds voltage well after car is turned off doing the same test, then it should be fine.
You're right, but I think he's just had a new battery put in. So Battery should not be the problem if its only 1 month old.
Something is draining current, either pull fuses with your multimeter connected so you know whats sinking the current, or take it to an autoelectrican?
And he's damaged it already by dropping down to 8V.
The ~0.1 drain is probably you alarm/immobilizer/stereo standby.
Don't worry about it, in a week (7days) it'll only drain ~17 amps out of your ~40amp battery.
Get a small smart battery charger (~$40) if your going to leave it longer than a week at a time without driving.
Didn't know you can 'kill' the battery if it goes below 8V. Ya reckon it's officially game over now for that bettery ?
Either way i'm switching over to larger CCA battery n be driving the car on Wed, Fri and weekends :)
Be keeping the battery as a spare reserve.
p.s. When you say smart battery charger, do you mean those that auto detect when the battery is fully charged up and it'll stop charging?
Below 10V is actually the kill zone, 8V is a promise.
Thing is, you might get another 3 months use out of it... and depending on your warranty, you might get a new one.
Yup, think Jaycar have 'em, my old work has em (12 Volt Shop), charge rate of 1 amp or greater would be ideal.
Be cautious about any electronic gear that Bunnings spews out.
ok sorry to butt in but my batt went flat few days ago too on my 34 and I jump started it with my neighbours car..all good..took it for a long drive down the coast and back no problems...tonight went and started it and its gone again...
Have stuck it on a charger and going to stick the batt back in tommorow..
Question: My new batt may have gone below 8V as per above when my alternator died a couple of mths ago...if I bring it back to claim warranty..is there anyway they can tell its been damaged?
They only know what you tell them. If you tell them your alternator died, then warranty will likely be refused.
At the end of the day, its worth a shot.
  • 1 month later...
Not sure if this is related to the battery but this battery / alarm thingy is starting to piss me off:
My alarm was working properly few days back and last night all of a sudden it's starting to go haywire.
Basically drove the car to a frd's place and arm the car as i usually do. After 2-3 mins, my alarm starts to go off and i just disarm it thinking i've accidentally pressed the panic button. Moments later after arming it, the same thing happen again.
When to the ct and parked at the car park and the same shit happened after i've armed the car. Same thing happened again when i went home and parked the car and arm it. I literally arm the car and place the keys in front of my hands.
Add ons: Boot release , central locking, motion sensors in the car
Do you know what's going on ??
I've just tested the car just now with the alarm and now it's working fine again so.... WTF ???? Is this due to a poor connection or some grounding issue?
hi chris
what do u mean 'sensors in car - clarify' ?
ya reckon it's the bonnet switch ? how do i check this switch ?
pop the bonnet, depress the switch tht triggers the alarm, arm the car and see if it goes off. Happened to me b4, the switch was not fitted properly.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
