  • Replies 175
what do u have to suit 18 by 12" wide wheels
nothing under 700, unless you want it stretched like a mofo
Hi,
Was wondering if you had the following for 225/45R17?
*Toyo proxxy 4
*Bridgestone Adrenalines RE001
*Falken RT615 and RT215
*Nexen N6000
Thanks for your time. Please PM me prices and availability asap =)
can u get dunlop dirreza z1s??
if not
dz101 or re01r
in 215/45/17 and 255 40 17
also what do u have in the way of 295s or 315s for 17's
Hi,
*Toyo proxxy 4
*Nexen N6000
pm sent
if not
dz101 or re01r
i have the dunlop direza dz101, but i dont have them in those sizes to match.
i only have 1 pair of the 255/40/17, can do them $190.
i have another pair in 265/40/17 if you want them wider.
215/45/17 are yokohama or pirelli if you want something good, price 150-175, kumho is cheaper.
nothing that wide in 17" sorry
wasnt aware u could get the dz101s in a 265.
did u do the dunlop z1s? (not dz101)
yes i only have 1 pair in the 265.
na buddy dont do the z1 s.
what do you have in 245/255 for R17 ?
im in need of 2, able to post to melbourne?
Sorry i missed this post earlier,
the 255/40/17 dunlops, price as above in 1st post.
245 dunlops as well.
i also have 245/45/17 toyo if like that as well.
No biggest right now is 275/30/19 in dunlop which i can do for a good price.
I have some 305/25/19 pirelli coming in,
otherwise i can order kumho or similar for you if you like
How much for the 275/30/19 dunlops and what else in a similar size can you source from other tyre manufacturers?
I can do the Dunlop Direzza DZ101 for $300/tyre. (on special)
Thats really all thats available right now,
The Kumho ku31 are also available, about $270/tyre.
Looking for a set of:
Federal 595RS either 235/40 17 or 245/35 17.
Let me know if you have them or can get them.
I dont do the federals mate
Hows it going mate..
If you could pm me your special discount's on semi's and what you have to offer.
225, 235, 245/50/16...
Cheers Tomek
Cheers Tomek
u got pm mate
hows it going
could you please quote me the cheapest set of 4 good tyres for 245/45/18 or 245/35/18 plus shipping to perth 6061? dont care about the brand, Thanks
how long is does the shipping takes?
cheers
hows it going
cheers
Hey buddy,
I dont sell any cheap rubbish tyres,
cheapest i get in that size is kumho ku19 at $200 delivered.
Otherwise i have name brands starting at 275 like yokohama.
can you get potenza re01-r?
No not right now, we are just focusing on the r888 right now, possible in the future though.
I need a set of DOT approved tyres to comply a vehicle
How much for a set of 4 in 235/45ZR17 delivered to Perth
Prefer a semi race or Bridgestone RE001 or anything you can recommend for the ocassional track work
Thanks
Thanks
pm sent
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
