hello can you please recommend a street legal semi for an xr6turbo 235/45 17inch rims for the ocassional track work but mostly used on the street , thanks
  • Replies 175
pm sent
You mentioned that you can get Yokohamas.
Can you source Yokohama V103's in 275/30/19 at all?
Cheers
Sorry buddy only the Yokohama ES300, and the dunlop direzzas.
hey mate, got 19" tyres?
pm me some prices on
235/35/19 If you have any in stock.
Thanks,
Steve.
Thanks,
Steve.
u got pm mate
after a pair of either 265/35/18 or 255/35/18
send me your price range, best to cheapest.
thanks
Hi mate,
what do you have in 245/40/17 ?
Looking for a pair of Kumhos or similar, specials, need to be in stock.
cheers
Tony
Hey Tony,
Cheapest i have is either the sumitumo(japanese tyres), or the fulda(usa tyres) for $160.
I have dunlop direzza on special for $210 each.
thanks
Hey mate,
have a look at my 1st post i have them all up with the discounted prices.
If you want something even cheaper let me know i can get something like kumho or cheaper if you want.
need 2x 235/40/17 bridgestone re001 or toyo r1r
Price thanks
Hey buddy, i dont have any of those in that size,,
i only have the bridgestone potenza re750 which i can do $180
Hey mate,
thanks.
mate looking for good tyre but dont need the top of the range.
what can you do for dunlop sports maxx?
what other tyres do you have?
maybe some hankook k104
also do you have hankooks new tyre, ventus v12 evo?
sorry no hankooks,
i can get you kumhos like the ku31, but the toyo specials i have on now in the 255 are the same price as those so i would be going for those instead.
Hey I was wondering whether you have toyo r1r's available. (are they released yet?) there website says late june/july 2008.
I am after 265/35ZR18 93W and a price if you don't mind please.
Thanks
Edited by Gads GTR
Thanks
Hey buddy,
dont have any of those yet, will probably be getting some over the next couple of months.
sorry no hankooks,
hi,
tried looking up those tyres on the net but couldnt find them. are they called vimode?
thanks!!
hi,
thanks!!
hmm, look harder, :)
they are 2 dif tyres, the toyo gu:wn, and the toyo vimode
gu:wn below
gu:wn
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
